Engine Stuttering At Low Revs, Especially When Cold
#46
Posted 26 June 2015 - 09:35 PM
#47
Posted 26 June 2015 - 11:31 PM
At throttle closed (and loss motion correctly adjusted) I have 0.814K ohms and full throttle (operated at the throttle body) is 4.65K ohms.
Conclusion the range of the TPS is reduced after mounting into the SPi throttle body and setting up of the throttle cable and linkages.
Span is 0.8K ohms to 4.7 K ohms with a smooth transition as the throttle was opened.
FS
Edited by FlyingScot, 26 June 2015 - 11:32 PM.
#48
Posted 29 June 2015 - 11:13 AM
New TPS ordered from Somerford Minis - good job it's just been payday! (I found a cheaper one somewhere else, ordered it and immediately got a phone call to say they were out of stock... :-( )
#49
Posted 01 July 2015 - 09:26 AM
#50
Posted 01 July 2015 - 03:10 PM
The only issue is the cost....now about £150!
FS
#51
Posted 01 July 2015 - 03:23 PM
You can have some limited success with a squirt of WD 40 but in reality once these wear they need replacing.
FS
And I'm guessing one of these won't cut the mustard, will it...?
http://www.ebay.co.u...=item28000b8d0b
#52
Posted 01 July 2015 - 03:46 PM
That's for an MPI I'm afraid and no good to you.....And I'm guessing one of these won't cut the mustard, will it...?You can have some limited success with a squirt of WD 40 but in reality once these wear they need replacing.
FS
FS
Edited by FlyingScot, 01 July 2015 - 03:47 PM.
Spelling on iPad grrrr
#53
Posted 01 July 2015 - 04:01 PM
FS
FS
Gah, thought not!!
#54
Posted 03 July 2015 - 07:59 PM
I got lucky a few years ago and a guy from 16v minis who is in our club gave me 3. They are also used on some other Rovers, I think the later metro and maybe the 214 K series engines. Had the same part number JZX something or another. I bet if you can find them listed as for these cars they would be cheaper!
#55
Posted 03 July 2015 - 08:50 PM
FS
#56
Posted 08 July 2015 - 09:02 AM
I found the proper SPi sensor from a brilliant Honda garage in Scotland who happened to have one in stock (and let me have it for £75 - new in its original packaging!!).
I fitted it yesterday and the difference is amazing - not so much as a stutter this morning, even with my foot down in fourth at low revs. Yay!
Thanks so much for all your help and advice, everyone!
#57
Posted 09 July 2015 - 12:51 PM
Hmmm... had a little stutter this morning. Time to check the vac pipes and (because I've got one kicking around) change the oxygen sensor...
#58
Posted 09 July 2015 - 01:43 PM
must have been some old spares stock from the joint Rover / Honda days (eg 214, 414 etc). I think they used the same part.
#59
Posted 10 July 2015 - 09:55 AM
Right. It's started happening again, so this weekend I'm going to:
- check the vac hoses and fuel trap for leaks/kinks/blockages
- take out the ECU, put it in a warm place and gently pop some cotton wool in the MAP sensor port
- check there's no crud in the nozzle that comes from the manifold (the one that the pipe going to the fuel trap goes on to)
- replace the oxygen sensor (if I can get to the wretched thing!)
- check the adjustment of the throttle cable
- check all sensor connectors/wiring
Anything else I should be doing?
#60
Posted 10 July 2015 - 08:06 PM
FS
