I autocrossed with them....did very well. Ran 36lb in front. Thats a set on 5" in my av pic actually
#46
Posted 01 October 2015 - 09:30 PM
#47
Posted 04 October 2015 - 07:10 PM
Ive have read that the KAD 6 pots with 8.4" vented discs will fit under some of the force rims, I have yet to try it, but this is the route I am looking of going.
#48
Posted 04 October 2015 - 07:40 PM
Depending on the inner rim width you may be able to run the wheels next to the 8.4 brakes.
Edited by Jon937, 04 October 2015 - 08:59 PM.
#49
Posted 18 October 2015 - 09:50 PM
Thank you for everyone's input so far
#50
Posted 18 October 2015 - 09:55 PM
#51
Posted 24 October 2015 - 07:17 AM
I'm assuming they are the same size as minisport 7.5" alloy calipers but just manufacturered from a single piece of alloy.
Edited by Jon937, 24 October 2015 - 07:29 AM.
#52
Posted 29 October 2015 - 03:28 PM
This has gone on quite a bit.
I think you need to prioritise whether it's aesthetics you want to focus on, or performance. I know both are important to some people, but if you want the performance of very big brakes, then you might have to sacrifice the aesthetics of small wheels... If you're talking about a rally car, then there is benefit to having smaller wheels/higher tyre profile.
If you are indeed aiming at a track day car, then is it purely the aesthetics of small wheels that you want? Surely a bigger wider wheel, with lower profile tyres (hence less tyre roll) is going to benefit you more on a smooth tarmac surface...
Just my 2p's worth.
#53
Posted 29 October 2015 - 03:43 PM
I threw a set of 12" wheels on my "track day" car that I always run 10" on to try it out. I only did one run....couldn't get the 10" back on quick enough....
On a MINI, the 10's are much better (IMO) that is .. 165's
#54
Posted 15 May 2016 - 10:33 PM
#55
Posted 16 May 2016 - 08:06 AM
#56
Posted 16 May 2016 - 10:03 AM
Hi I've had dealings with this company Az-Tech Ltd who make 4 pot alloy calipers, I bought these to fit under 10" cooper s reverse rims and they do not fit along with the Mamba wheels due to the internal offset. I returned the calipers no problem.
I now have the Weller 10 x 5" steel wheels and Kev at Az-Tech is brilliant he sent me a blank caliper and spacers to get the correct alignment on the discs.(he makes the Minispares calipers) so when I'm ready I will be buying these as the quality and service is excellent.
#57
Posted 16 May 2016 - 05:14 PM
How much does the 7.5" setup sit out from the ball joint centre; I have the 8.4" setup atm so can measure that but just wondering what difference there is?
IIRC they are as near as damit the same.
Edited by nicklouse, 16 May 2016 - 05:14 PM.
#58
Posted 23 August 2017 - 03:23 PM
Looking at these wheels, I know they will fit over the 7.5" discs with 4 pot ally calipers but would they fit archless with either 145 or 165 tyres?
#59
Posted 23 August 2017 - 04:12 PM
http://bmccomps.co.uk/products.php
#60
Posted 23 August 2017 - 04:24 PM
Thank you grizzler
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , Yesterday, 05:50 PM ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
