#31
Posted 17 June 2015 - 09:31 PM
That's fair enough with adding a servo for a nicer feel.
#32
Posted 17 June 2015 - 09:55 PM
#33
Posted 17 June 2015 - 10:15 PM
I wouldn't mind knowing this myself, I warped 3 sets of 8.4 solid discs in 2 years on my MPI and I'd like to run it archless when it's rebuilt.
#34
Posted 17 June 2015 - 10:25 PM
But as the the vented discs can push the mounting face further out this can cause issues, but if you are having wheels made then it is not an issue.
And then you can also have the drive flanges made to suit the discs which can also be made to fit a certain size/offset.
But you still have a limited rim width and tyre foot print and limited grip.
Then you put massive brakes on it that require less pressure go give the Retardation you want which will mean you will have next to nothing at the rear.
A major braking imbalance can be an issue at the MOT. So think on to your MCs yes you might need a proper set up with different piston sizes and adjuster. And you will still lock your brakes up.
#35
Posted 18 June 2015 - 04:21 PM
#36
Posted 18 June 2015 - 05:16 PM
#37
Posted 20 June 2015 - 12:31 PM
Does anyone know the distance from the mounting face on the 4.5" cooper S to the spot welds holding the centre of the wheel to the outer rim?
#38
Posted 20 June 2015 - 12:49 PM
I doubt this is anything new but I fitted Metro vented discs under 12" steels. I used the Mini drive flange and had to fit spacers between the calliper and hub as there is a difference with the drive flange somewhere.
I remember people talking about Fiesta callipers but not sure what ones. I think being single piston sliding ones they fitted with 10" wheels don't know about the discs though sorry.
#39
Posted 23 June 2015 - 12:16 PM
Did anyone remeber which Fiesta calipers can be used under 10" wheels ?
Do the KAD 4 pot calipers have dust seals for the road?
#40
Posted 24 June 2015 - 11:53 AM
You need mk2 fiesta solid disk calipers
Edited by Gr4h4m, 25 June 2015 - 08:54 PM.
#41
Posted 26 June 2015 - 11:23 AM
Yep the KAD four pots have dust seals and IMO the best four pot kit on the market.
Thanks Gr4h4m, I put them on the car so long ago ( about 12 years) i couldn't remember.
#42
Posted 09 August 2015 - 09:48 PM
Do rose petal wheels still fit archless when using discs?
#43
Posted 01 October 2015 - 07:51 PM
I'm having some issues with the website but wondered if these would fit 7.9" brakes, if not then alloy 7.5" calipers.
And whether both or either of these brake options would still allow the wheels to be fitted without arch extentions?
#44
Posted 01 October 2015 - 08:47 PM
But then you have a very poor tyre shape. 165 need to be on a 6" rim really.
Not at all.... They work very well with 5" and I imagine pretty well on 4.5" also. Not 3.5 though.
Edited by Spitz, 01 October 2015 - 08:48 PM.
#45
Posted 01 October 2015 - 08:56 PM
Could never ever get on with 165 on less than 6" rims. Like jelly.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , Yesterday, 05:50 PM ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
