Couple of questions:
When fitting a Rear Valance and Closing Panels (With Subframe Reinforcement Brackets Fitted) what's the best way to weld them in place, bolt up the Closing Plates to the Subframe, clamp on the Rear Valance and then weld the whole lot in?
Or
Bolt in the Closing Panels and clamp on the Rear Valance and tack weld the Closing Panels to the Rear Valance, remove the lot, finish welding the Closing Panels to the Rear Valance (To avoid doing it under the Mini. And then refit the Rear Valance and Closing Panels and then finish welding the lot together?
Also, where and how many holes should I drill into the Rear Valance Closing Panels to Spot Weld to the Floor of the Mini?
These ones:
