A few notes before you start.
1) If you buy that kit, you will still need to purchase a flaring tool to make the ends. That will add a bit to the cost, research that first.
2) That kit seems to use copper tube. There are widely varying debates as to the suitability of copper versus copper nickel. Copper nickel (cunifer, kunifer) is designed for this, and copper is debated (some say safe, some say not). I'd personally spend a few extra bucks to get the definitely correct one, especially when considering the work needed to put it in. If the pipe bursts, that's going to happen during a situation like a panic brake when a kid runs in front of the car, etc.
3) Don't just look at the threads of your tube nuts to determine which type to use. Check the "Common Crossthreads" section of this page:
http://www.fedhillus...mon flares6.pdf
The 3/8 x 24 UNF American nut will thread very easily and loosely into a 10mm x 1.0 thread fitting but will hopefully strip the threads when you tighten it down
You can start the 10mm x 1.0 thread nut in a 3/8 x 24 UNF thread fitting but it will immediatly begin stripping the threads
Edited by zerobelow, 11 June 2015 - 08:12 PM.
