Hello folks,
I have a '97 MPI with a weird cooling problem!
The coolant is expanding in the expansion tank and leaking but the temp gauge suggests that the engine is not overheating. I'm pretty certain the gauge is working because the mini was overheating earlier this year due to a seized cooling fan. I replaced this and at that time flushed the cooling system, fitted a new temp sender and a new thermostat. The fan still cuts in as required but with the engine running at normal I still have this issue with the expansion tank overflowing. Any ideas?
