Lots And Lots Of Good Bits With Pictures!
77 replies to this topic
#1 blue blood
blue blood
  • 806 posts
Posted 18 May 2015 - 07:43 PM
Items left from selling my project. Hold on to your butts...
Brand New Stainless Steel Braided Fuel Hose, just under 3meters in length and one piece just over 1.2m in length with an internal diameter of 8mm. £20
Brand New Toggle Switches 12V One Red One Green LED. £2
Engine mounting bracket £12
Standard Handbrake £5
MPI brand new standard fuel filter £5
Various door hinges £5 per hinge
Brand New Savage Switches £12 per switch
Types include: Latch rear screen, latch main beam, latch full beam, latch hazard and brake warning light.
Door lock mechanisms left and right £8 pair
Alloy gear knob £3
Stainless steel spreader plates for twin bolt subframe (perfect for any min based kit cars) £15
Clear plastic indicator lenses £3
MPI Silicone Blue Spark Leads £10
MPI Standard alternator top mount £8
Two new fuse holders and one used fuse holder £8 for all
Brand New Number Plate LED Nuts (not the really cheap type) £7.50
Stainless Door Scoops £3
Tex Window wipers with good blades £15
Brand New Stainless Ties for exhaust wrap £3
Custom  MPI Alternator brackets (lowers the alternator to fit under a minus bonnet with no bulges) £10
Brand new cigarette lighter unit with alloy collar £2
Brand New Stainless Hose Clamps 51-55mm £5 for the pair
Universal bucket seat runners in good working condition (suit Cobra buckets) £15 pair
13 Brand New P Clips 8-10mm £3
Working Washer Pump £3
Brand New Wheel spacers 3mm £3 pair
Brand new rocker cover seals and aluminium washers £2 pair
MPI Thermostat housing with extra brass take off £10 (perfect for a mini based kit car)
Location Stourbridge all prices shown exclude P&P
Regards Blue
#2 blue blood
blue blood
  • 806 posts
Part 2
Brand New Thermostat and Gasket £3
Brand New Glass Inline Fuel Filter £2.50
Brand New Universal Washer Bottle £4
Brand New Universal Adjustable Fan Thermostat Kit £20
500 gear knob £5
Stainless Steel Wiper Motor Holder £5
Brand New Stainless Verto Clutch Bracket £35
Brand New MPI Stainless Ignition Bracket £35
Genuine Trigger Handbrake As New (fitted once) £80
New MiniFins made in UK £65
Brand New Black Handles £40
New Alloy Billet Door Hinges Black with stainless steel bolts £100
Heated front windscreen only test fitted never wired in fully E marked £110 (collection only)
Rare to find rear window with silver heater elements (not orange/brown) £50 (collection only)
Brand New KAD billet alloy MPI water pump belt wheel £40
Brand New Titanium stud and nut kit for thermostat housing and radiator take off £20
Stainless DTM exhaust and centre pipe (for better performance) £25
New silicone MPI hoses both top hose and main hose made by Artel. £100
Gear Linkage £10
Reconditioned Inlet manifold silicone hose with: fuel rail, injectors (new O-rings), brand new piper cross air filter system, silicone hose to air sensor £150
ECU fully polished and sprayed  comes with fob and alarm unit £110
Alternator off an MPI mini not sure of condition £10
New Uprated MPI radiator UK made (only dry fitted in place) £170
Brand New hardened Drive shafts fully painted up in rust bullet (paint which makes hammerite look like watercolours!!) £80
New compact car heater from car builder solution, comes with a custom made stainless steel holding bracket and a custom cut carbon fibre front face. This heater takes up less space than the original heater but will be more effective than the original £150
Bosch fuel-pump in good condition mirror polished and wrapped in a rockstar can, with a black alloy cradle and a segment of new braided fuel hose and black alloy hose connector finisher £100
Sytec alloy fuel filter £40
Alloy lockable fuel neck, cap and restrictor this is also needed to pass an IVA test as it locks and restricts fuel nozzles that aren’t petrol, it is also mounted on a custom cut carbon fibre panel for mounting in the corner of a boot opening £80
11041491_10206306251878530_968835700_n_z
Rear lights set up, these have been cleaned up etched primed finished in satin black with new bulbs and brand new crystal light covers, come with new seals £75
11103952_10206306196677150_961648878_n_z
Repro right hand inner hinge cover panel £5
#3 Richie83
Richie83
  • 1,495 posts
Posted 18 May 2015 - 07:48 PM
Interested in the 500 knob. Could you on postage to UK mainland please?
#4 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 18 May 2015 - 08:36 PM
I assume the black handles are only just the two door handles?
#5 blue blood
blue blood
  • 806 posts
Postage for the 500 knob is £4 on the price (its quite weighty as its a pretty solid piece of metal)
#6 blue blood
blue blood
  • 806 posts
Posted 18 May 2015 - 08:37 PM
Yes the black new old stock rover door handles
#7 CAU998
CAU998
  • 1,202 posts
Posted 18 May 2015 - 08:45 PM
Could you do £35 Inc postage to UK mainland?
#8 blue blood
blue blood
  • 806 posts
Posted 18 May 2015 - 09:10 PM
Hi mate the price £40 without postage. They are brand new not even test fitted and retail alot more than what I am selling them for. Id do £46.50 posted but thats the best I can do.
Regards Blue
#9 CAU998
CAU998
  • 1,202 posts
Posted 19 May 2015 - 03:45 AM
Do the locks match? Or are they both different? Cheers
#10 blue blood
blue blood
  • 806 posts
Posted 19 May 2015 - 06:32 AM
Different. These items are now provisionally sold payment pending.
Regards Blue
#11 Omz45
Omz45
    Just On Tickover
  • 9 posts
Posted 19 May 2015 - 09:52 AM
How much would delivery of the clear indicator lenses and fuse boxes be plz?
#12 Hitz_x
Hitz_x
  • 19 posts
Posted 19 May 2015 - 10:46 AM
Hi blue
Where would collection be from?
#13 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 19 May 2015 - 11:10 AM
Have you still got the seat runners?
#14 blue blood
blue blood
  • 806 posts
Posted 19 May 2015 - 04:42 PM
Hi blue
Stourbridge Amblecote mate so not far from Dudley.
#15 blue blood
blue blood
  • 806 posts
Posted 19 May 2015 - 04:43 PM
I'd say £6 for P&P for the items together mate.
