What Oil In Dash Pot
29 replies to this topic
#1 MINIMADrt
MINIMADrt
  • 465 posts
  • Local Club: none at mo
Posted 11 May 2015 - 06:09 AM
What is the best oil to put in the carb dash pot
Cheers all
Edited by MINIMADrt, 11 May 2015 - 06:34 AM.
#2 Dusky
Dusky
  • 5,322 posts
Posted 11 May 2015 - 06:37 AM
Let the fight begin. ;)
I prefer a quite ligh toil ( ATF).
20W50 as some people will say is way too thick. Standard SU oil is SAE 30 if I recall right.
#3 One step at a time
One step at a time
  • 282 posts
Posted 11 May 2015 - 07:12 AM
Just use a bit of your engine oil, no need for anything special.
#4 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 11 May 2015 - 07:23 AM
All I use is my engine oil. Halford classic - 20W50
#5 MINIMADrt
MINIMADrt
  • 465 posts
Posted 11 May 2015 - 07:28 AM
Perfect cheers for the quick reply I use to top up with the engine oil on my old mini but this one is bone dry and and that was 5 years ago. I have 4 days to build up from a shell for the big run so no rest for the wicked.
#6 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 11 May 2015 - 07:33 AM
ATF like Dusky said.
#7 timmy850
timmy850
  • 3,289 posts
  • Local Club: MITG
Posted 11 May 2015 - 07:39 AM
I lost a fair bit of the oil in mine mine so topped it up with 20/50 and it was too thick and was making the throttle slow to react when cold.
I've got some Penrite SU damper oil in it now, and it is much better. The SU brand oil is 20 weight:
http://sucarb.co.uk/...e-grade-20.html
#8 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 11 May 2015 - 08:56 AM
Mine currently has 66% 20/50w and 33% Air-tool oil (10w)   :geek:  It's taken a long time to get it right but the mixture and response is just about bang on now.
#9 Ethel
  • 25,891 posts
Posted 11 May 2015 - 09:13 AM
As Dusky says it's a hardy perennial on TMF
The damper stops piston flutter and also provides the enrichment that other carbs have an accelerator pump for. Thicker oil gives more enrichment as it slows the piston rising: creating more depression across the jet. It may be counter intuitive, but if the car hesitates when you put your foot down you're more likely to need thicker than thinner oil - after you've eliminated the many other likely causes of course.
BL/Rover specified the same oil as the engine, so that is probably the best place to start.
#10 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 11 May 2015 - 11:04 AM
sae 20 motorbike fork oil
#11 racingbob
racingbob
  • 3,061 posts
Posted 11 May 2015 - 12:02 PM
I use 3 in 1 oil seems good
#12 Cooperman
  • 23,259 posts
Posted 11 May 2015 - 12:42 PM
3-in-1 or air tool oil seems to work fine.
#13 fenghuang
fenghuang
  • 796 posts
Posted 11 May 2015 - 01:52 PM
I put 20/50 in and struggled when the engine was cold. (As I understand it that's the 50 bit of the 20/50 : 20 when when hot, 50 weight when cold.)
I've bought a bottle of SU oil for less than £5, but not got round to trying it yet. I figure if it's that cheap, no one's gonna know better than the folk who build the carbs.
#14 blacktulip
blacktulip
  • 6,224 posts
Posted 11 May 2015 - 04:58 PM
I have always used 3 in 1 oil so can't vouch for anything else.
#15 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 12 May 2015 - 06:55 PM
+1 as you asked what's best not what is OK!
