Ditching The Brake Servo, What Is Involved
Posted 08 May 2015 - 09:40 PM
Reinstalled my engine today and the pesky brake servo was once again something I did not like having in my way.
Was planning on removing it anyway, whats involved in removing the servo and fitting a different master cilinder?
Posted 08 May 2015 - 09:43 PM
If remote just relocate somewhere else. Dual circuit and servos I never had.
Posted 08 May 2015 - 09:51 PM
Posted 09 May 2015 - 07:38 AM
Edited by 666junky, 09 May 2015 - 07:41 AM.
Posted 09 May 2015 - 07:56 AM
Can't you just reroute the pipes to right shape and fit the right nuts if the threads are different? Then drill/grind the rivet off on the pedal rod, the upright M/C has the rod on it.
Posted 09 May 2015 - 09:03 AM
It is a LHD car with the servo mounted in the engine bay, it look like its directly attached to the MC.
Posted 09 May 2015 - 10:54 AM
The servo clevis pin is bigger than the cylinder pushrod one so what you would have to do is remvoe the pedal from the car, drill the old rivetted pin and remove the push rod, match drill the clyinder clevis and pedal to suit a larger clevis pin and then reinstall everything. If you don't do that you get a fairly noticeable amount of additional lost travel and the clevis pin wears as it slops around. It's easier to swap the pedal.
The servo itself isn't in the way of anything. The easiest solution is to replace the hard lines running from the M/C to the FAM7821 valve with flexible lines. Then you can easily move the cylinder out of the way without disturbing the system. The flexible lines are available as kits from the bigger specialists.
Given how tight you've said in the past that some of your MOT rules are over there, how legal would ditching the servo be?
Posted 09 May 2015 - 11:06 AM
Hmm, MOT is indeed something I should think about ;
although I don't think they would notice the difference ( they don't know that much about mini's, only obvious things are forbidden). ( Like braided brake hoses as a stupid example)
ANyway, my biggest reason for ditching the servo is that I don't use it now. ( It's disconnected). But a little question : Does the servo always draw air? Or only when braking? And can I check it for air leaks?
thanks, you guys are great! ;)
Posted 09 May 2015 - 11:11 AM
the master cyl can be unbolted from the servo & gently moved over to the wing - giving a lot more room
only do this if the pipes are good - if the pipes are old , they probably needs replacing anyway also watch out for fluid spilling out
done loads of engine swaps that way
servo only releases air into manifold after use - to equalize with manifold vacuum - (revs should increase after pedal is released for a sec)
Edited by sledgehammer, 09 May 2015 - 11:12 AM.
Posted 10 May 2015 - 11:13 AM
Posted 24 February 2023 - 04:36 PM
I know that this thread is a bit old. I am getting ready to ditch my brake booster for a standard master cylinder
I have a LHD Mini with a brake servo (and the cross-over bar for the pedal)
I have purchased the dual port upright master cylinder as well as the pipe kit that Mini Spares sells
I am assuming that I can just remove the entire booster and brake setup in the engine compartment.
Remove the rod that connects the crossover bar to the servo mechanism in the engine bay and install the new master cylinder and brake lines.
It is that straight forward? Or is there some other customization needed?
Posted 24 February 2023 - 06:15 PM
You'll need the Master Cylinder as you've already mentioned and also an earlier LHD Pedal Box along with the pipes.
Posted 24 February 2023 - 06:36 PM
My goal is to actually mount the master cylinder on the right where the booster is now. Utilizing the crossover bas that's already in place. trying to avoid replacing the pedal box
Posted 28 January 2025 - 06:45 PM
Posted 28 January 2025 - 06:58 PM
16 user(s) are reading this topic
0 members, 16 guests, 0 anonymous users
