Timing Belt Conversion - Replacement Belt
35 replies to this topic
#1 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 May 2015 - 03:24 PM
Has anyone been able to get a replacement belt for the timing belt conversion that minispares now very helpfully no longer support?
#2 Midas Mk1
Midas Mk1
  • 5,777 posts
  • Local Club: S.U.N.M.C
Posted 01 May 2015 - 03:41 PM
I'd be interested in this too, think I have a Minispares belt drive setup.
#3 Ethel
  • 25,922 posts
Posted 01 May 2015 - 04:26 PM
Naughty of them, I thought they sourced a new supplier in Italy a while ago ???
SH Engineering have 'em listed on their site for £29 a pop. Dunno if they are compatible with the Minispares kit, but seems likely.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 01 May 2015 - 04:30 PM
If you get stuck, I know a company that does hundreds of drive belts in all sorts of profiles and length so may be able to help.
#5 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 May 2015 - 04:45 PM
I called minispares earlier this afternoon and got the normal standard of customer service!
Just sent an email to SH, fingers crossed.
Thanks, I have been trying everything I can think of this afternoon and apparently gates do an industrial belt which is compatible but no one seems to be able to get the industrial side of gates stuff.
#6 Ethel
  • 25,922 posts
Posted 01 May 2015 - 05:07 PM
It's a 52 tooth belt 19mm wide.
SH's site mentions Gates. My (Minispares) spare is marked Pirellli Isoran 52 R 190. Googling chucks up loads of Isoran R190's and the 52 would relate to the number of teeth.
#7 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 May 2015 - 05:11 PM
It is indeed, and square profile teeth, the kits you can buy now from other places all seem to use another belt with rounded profile and is totally different.
#8 Ethel
  • 25,922 posts
Posted 01 May 2015 - 05:39 PM
Plenty of googling & Turbo minis got me to
http://www.royalsupp...tm#.UoDmgcsaySM
#9 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 May 2015 - 05:45 PM
I found that as well, I fear it is going to take longer than I can afford to arrive from the US though, got two weeks until the IMM and I need to re-build this engine.
#10 Ethel
  • 25,922 posts
Posted 01 May 2015 - 06:25 PM
Just found a spare, spare belt. Yours if you want to risk it, unknown mileage and been sat a while.
#11 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 May 2015 - 07:12 PM
Just had an email back from SH and as soon as it became known he had them they all flew out, bugger! Hmm, I might well take you up on that, I just need this engine to get me to Lithuania for the IMM and back again, at least I could carry yours as a spare with me, thanks. Will get in touch if it comes to that.
#12 Spider
  • 14,849 posts
Posted 01 May 2015 - 07:28 PM
Mini Mania in the US had Kevlar Belts, while I haven't looked recently, I'm sure they still have them. No one else I looked at had the Kevlar ones.
Yeap, just looked, still have them;-
http://www.minimania...ion-Kevlar-Race
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 02 May 2015 - 08:27 AM
If it's a known profile then it could be worth giving Transdev a ring (the guy I deal with is called Brian and knows his stuff on belts) as they supply thousands of different profiles and lengths and can match most things.
#14 carbon
carbon
  • 2,590 posts
Posted 02 May 2015 - 09:27 AM
Clive, thanks for the suggestion about Transdev.
I'm running a couple of these Minispares belt drives, with one the belt is almost 30 years old and the other is 20 years. They have not racked up a large mileage, but I will need to change them...
Edited by carbon, 02 May 2015 - 09:28 AM.
#15 Ethel
  • 25,922 posts
Posted 02 May 2015 - 10:58 AM
It does seem to be the same as most cam belts, just shorter.
