Conversion From Three Clock Dash To Center Binnacle, Help.
6 replies to this topic
#1 nigel
nigel
  • 134 posts
Posted 29 April 2015 - 09:29 AM
In the process of fitting the center dash binnacle and clocks / gauges. bought the complete kit from m/s.
putting this in a 1993 mini. i dont have too much of a problem soldering the existing loom onto the smiths kit loom as its pretty much self explanatery and colour to colour.
BUT not to sure on what wires in the new loom with kit goes to the fuel gauge, voltage stabiliser and the OIL gauge.
Ive always had mechanical oil gauges which are simple as you just connect the oil feed pipe to it. however this is the first time ive fitted the type with two spade connectors on the back so any idea  what colour wires go to it from the loom??.
Also i only have one wire from the oil sensor on the block and that colour wire does not correspond with any in the new loom.
The diagrams with the kit is crap, doesnt tell you any colours.
hope someone on here has the answers. thanks :-)
#2 jaydee
jaydee
  • 8,565 posts
Posted 29 April 2015 - 09:57 AM
The voltage stabilizer is marked B where it goes to the 12v supply and I where it has to go to the instruments. Its indifferent which terminal you use for the temp and the fuel gauge..its the same feed.
These are the colours
- White - - - Ignition live.
- Black - - - Earth.
- Green with red - - - Left indicator warning light.
- Blue with White - - - High beams warning light.
- Green with blue - - - Water temperature gauge feed.
- Green with back - - - Fuel gauge feed.
- Green with White - - - Right indicator warning light.
- Red with green - - - Dash illumination.
- White with brown - - - Oil pressure warning light.
- Brown with yellow - - - Ignition warning light.
What type of oil gauge is that?
#3 nigel
nigel
  • 134 posts
Posted 29 April 2015 - 06:27 PM
Thanks for that, oil gauge is a smiths.
#4 nigel
nigel
  • 134 posts
Posted 29 April 2015 - 07:48 PM
So does the white cable in the wiring loom that come with the dash kit go to the "B" on voltage stabiliser??
#5 jaydee
jaydee
  • 8,565 posts
Posted 30 April 2015 - 09:05 AM
Yes, and i add, as always with classic cars check with a multimeter, you never know the history of a used wiring loom..when you switch ignition to II you will have a costant 12,6V on the white terminal
From memory a mechanical smiths oil pressure gauge should have two electrical feeds, one is illumination, the other is the ground for the bulb
#6 finch661
finch661
  • 2,339 posts
Posted 01 May 2015 - 01:25 PM
worth a quick read
http://www.theminifo...-centre-speedo/
#7 Mk1Dave
Mk1Dave
  • 519 posts
Posted 08 May 2015 - 01:59 PM
Hope this is of some help. I'm using a loom I got from minispeed if it makes any difference. I used the above guide which is spot on.
