Ashtray Clock
68 replies to this topic
#16 1984mini25
1984mini25
  • 8,784 posts
Posted 28 April 2015 - 12:49 PM
some boy on here was making a sick one berfore, had a clock, fuel guage, he was even looking into a temperature guage
cool though, anyone of making a bit less 80s?
There will be lots of versions available if all goes well, not just clocks but lots of plug and play easy fit applications, Gauges, chargers, display screens, you name it and if there is a demand it can be made.
The later interior light also fits (just) as mine is held/wedged in place by two bits of rubber trim. Would be nicer to have a proper bit of trim to fill the gap and make it look neater.
Edited by 1984mini25, 28 April 2015 - 12:49 PM.
#17 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 28 April 2015 - 01:00 PM
That shouldn't be to hard to do as long as there is enough space for clips etc.
#18 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 28 April 2015 - 01:10 PM
I wouldnt mind one too with integrated battery due to me cutting power from battery every time I leave my Mini parked anywhere (can you say paranoid!!!)
#19 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 April 2015 - 01:45 PM
Im going to convert my one into a volt meter (red leds) and amp meter (blue leds) all in one meter with a 200amp shunt in the boot.
  200 amps isn't enough unless you've got an aftermarket geared type starter motor.  The stall current of all the motors used on Minis as standard is 360-375 amps.
#20 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 28 April 2015 - 01:57 PM
I think they'd sell well.
Would it be possible to wire it into the car but include a seprate battery to keep it going if the main car battery was disconnected? The radio on my daily does that so I don't need to enter the code.
#21 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 28 April 2015 - 04:11 PM
You've got my interest!
#22 Samo
Samo
  • 89 posts
Posted 28 April 2015 - 04:13 PM
I would be interested
#23 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 28 April 2015 - 05:34 PM
Also considering doing switch surrounds in coloured plastics and carbon (for standard and savage style switches), all will be laser cut.
But that will not be until after the clock project.
#24 pusb
pusb
  • 1,216 posts
Posted 28 April 2015 - 06:13 PM
I would be interested to see if this could be converted into an outside temperature gauge.
#25 Juniors mini
Juniors mini
  • 93 posts
Posted 28 April 2015 - 06:22 PM
The shunt is for my ICE install side only.
#26 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 28 April 2015 - 06:27 PM
Not a problem, clock with outside temp gauge already on the list :)
#27 Spider
  • 14,836 posts
Posted 28 April 2015 - 06:30 PM
I've read here a few guys would like a back up battery, probably not a bad idea.
In the car I have mine in, I found if I had to crank it for anything longer than about 10 seconds, the volts to the clock would drop enough for it to loose it's memory. I fitted a diode and a 2000 micro cap to the live feed to it to over come that. That worked a treat for this, but if a battery isolator is used often, then a batter would be the way to go.
I just hate having to remember to change the batteries in these things and inevitably, the battery is usually some weird arse thing that I don't have!
#28 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 28 April 2015 - 06:40 PM
Battery backup is 100% going to be on all variations i consider, using a CR1220 battery available everywhere for a few pennies.
If i go ahead with this (looking more likely every minute) i intent for them to be a decent product that will last.
#29 redmini963
redmini963
  • Just Joined
  • 98 posts
Posted 28 April 2015 - 06:47 PM
sounds great just what i need with battery back up
#30 hankins
hankins
    Mini Lifesaver
  • 338 posts
Posted 28 April 2015 - 07:31 PM
** UPDATE **
Mould should be ready by next week, so can make the first copy of original and then start on remodelling that to accept different clocks and accessories.
Should have some prototypes pics up in the next two weeks for you guys to scrutinise.
