Hi,
I'm new to the forum and this is my first - and seemingly stupid - question.
I have been trying to deal with a rich / high rev idle problem on my '95 Cooper. I have previously replaced leaking vacuum hoses from the inlet manifold to the vapour trap and from the vapour trap to the MAP, and flushed the cooling system which was heavily corroded and full of gunk. This made a difference, reducing the idle speed from @2000 rpm to 1500rpm, which still seems high.
Today I removed the inlet manifold to have a peek at the coolant temperature sensor and this is also in bad shape and has obviously been played around with in the past.
While everything is stripped down I was going to change the lambda sensor. I haven't run a diagnostic but was going to replace as there's no record of it being replaced in the past and there is 100K on the clock.
Problem is that I can't find the lambda sensor - there is nothing around the exhaust manifold. I have looked, honest!
There seems to be a sensor on the exhaust front pipe - in between the catalyst and down pipe - but no idea what this is and whether I should tinker with it. There seems to be a lambda sensor heater relay near the inertia switch but this heads down into depths of the engine block, and I could be wrong that it's lambda-related. Is there a chance a previous owner has fitted on a non-injection exhaust manifold? Could an injection car function without one?
Any advice appreciated.
Simon
