Operation: Nancy
#91
Posted 31 December 2006 - 08:46 PM
#92
Posted 02 January 2007 - 05:33 PM
The only problem ive come across today is the door hinges. Some numpty has put them on and rounded the heads off all the fasteners! So Im thinking about just getting the grinder out and cutting through the hinges, unless someone has a pear of wisdom? I dont think there is enough room to drill the fasteners out.
Also, with the front and rear glass, is it just a case of easing back the seals and the windows should come free?
#93
Posted 03 January 2007 - 10:36 AM
Ok, Ive spent a few hours stripping Nancy out. Everything i could possibly think of has come out, apart from things needed to give her 1275 a last run when guywithvan comes to see it (hopefully soon).
By the sound of it your trying to undo the big screw heads inbetween the door and a panel? If you look from under the wheel arch you'll see four small bolts holding the complete hinge that are alot easyer to undo than the screws. Just remeber to keep the correct spacer setup when removed.
As for the windows remove the chrome strip from the centre(should just pull out) Then gently from the inside push the window from one of the corners. Have someone on the outside to steady/catch the glass as it come free. I usually use my foot to push the glass but i usually have seats in the car.
Edited by Peskett, 03 January 2007 - 10:41 AM.
#94
Posted 03 January 2007 - 10:46 AM
#95
Posted 03 January 2007 - 10:54 AM
#96
Posted 03 January 2007 - 11:00 AM
#97
Posted 03 January 2007 - 11:02 AM
#98
Posted 03 January 2007 - 11:49 AM
#99
Posted 04 January 2007 - 11:47 PM
I promise that within the week there will be some progress!!
So where is this progress that was suppose to happen before the end of the week which was about a week ago??
#100
Posted 05 January 2007 - 12:07 PM
So next week, after pulling the a-series, Ill be putting my engine back together whilst waiting for my cage to arrive.
#101
Posted 05 January 2007 - 12:20 PM
#102
Posted 05 January 2007 - 06:55 PM
#103
Posted 05 January 2007 - 07:36 PM
#104
Posted 05 January 2007 - 07:43 PM
#105
Posted 05 January 2007 - 07:46 PM
on my 24 off all i want to do is sleep!
and you call yourself party boy
