Operation: Nancy
#16
Posted 23 July 2006 - 10:32 PM
#17
Posted 23 July 2006 - 10:37 PM
Im gonna have to try again in a couple of weeks as im away for a bit. Gonna get my a meaty 1/2" jobby methinks! Any chance of borrowing your tool? might make it a little easyer! where abouts are you?
Im at Ongar Essex. You more than welcome to borrow it, but its abit too hefty to post.
The tools not hard to make aslong as you can weld, i'll try and describe it:
Abit of box section, with two tabs on the end which go over the the nut, then between the tabs the rachet need to go through so it can get on the nut. Jam the tool to the floor so it wont turn then undo the nut with a huge sway bar.
You can actually but them but they're like £50.
#18
Posted 23 July 2006 - 11:14 PM
#19
Posted 24 July 2006 - 10:37 AM
#20
Posted 24 July 2006 - 11:47 AM
What sort of look are you going for with you boot lid? Are you trying to keep it stealthy? And how are you tackling the possible air-lock problem with mounting the rad in the boot?
#21
Posted 24 July 2006 - 11:54 AM
Edited by Jobu, 24 July 2006 - 11:55 AM.
#22
Posted 24 July 2006 - 11:56 AM
Any guesses on a price?
A clue is that its more than i paid for the whole engine!
Mr. honda wants just over £600 just for a new throttle body! Looks like im off to try my luck at the scrappies!
It un-does the same way as the pully turns, which is anti-clockwise i think cant remember.
Good good, I havnt made my life a whole lot harder then!
#23
Posted 24 July 2006 - 12:00 PM
Honda parts: (01582 606800)
Where i got my engine from, he should have one.
#24
Posted 24 July 2006 - 01:36 PM
I think it will be like the Auto Delta mini bootlid. I'll find you a pic if you want?What sort of look are you going for with you boot lid? Are you trying to keep it stealthy? And how are you tackling the possible air-lock problem with mounting the rad in the boot?
I'll be using the same system used in my MR2, two bleed valves, one engine side, one radiator side. Then follow the same sort of procedure for bleeding a rear engined car.
#25
Posted 24 July 2006 - 03:46 PM
If you get inlet-outlet ratio right you could get yourself a slight bit of ground effect at high speed (bit of a crude way to go about it tho)
#26
Posted 24 July 2006 - 08:12 PM
Can i just double check with you VTEC guys, the crank pully bolt is a right-hand thread and i havnt been tightening it up even more?!?!?
Spoken like a true Leckie/Armouror!!
Have you tried the 2 scrappies in Grantham? They were really helpfull last time i used them and have a good selection of cars.
Anyway, good luck mate
Gary.
#27
Posted 25 July 2006 - 06:38 AM
I tried two scrappies in Peterborough with no luck, Ill try Grantham on the weekend, or possible next week because of payday.
Take a look at this guys conversion, it was in mini mag a few months back http://www.vtec-mini.co.uk/
Edited by Bounce, 25 July 2006 - 06:41 AM.
#28
Posted 25 July 2006 - 06:52 AM
#29
Posted 25 July 2006 - 07:35 AM
#30
Posted 25 July 2006 - 02:10 PM
If you dont mind me asking, how much did the engine and loom cost? I phoned a scrappy a few months back and they quoted me £950, which i think i WAY over priced (80,000 miles and no service history).
Is 20 still full of bell ends? I am in Porstmouth at the minute and i am still hearing stories about how poo 20 is, so i am definately not looking forward to joining.
