To Shell And Back
130 replies to this topic
#61 feybrand
feybrand
  • 1,247 posts
Posted 03 December 2015 - 06:50 PM
ye it runs off the regular sockets ....it depends which one you buy i got mine from machine mart they sell 2 the cheaper one works of a regular socket the more expensive one doesnt
chepest one has no frills aswell ...no timer etc and can only weld 1mm +1 mm metal
#62 Stu.
Stu.
  • 912 posts
Posted 03 December 2015 - 07:47 PM
Great Ta. Do you find yours does the job ok one you got used to it?
Edited by Stu., 03 December 2015 - 07:50 PM.
#63 feybrand
feybrand
  • 1,247 posts
Posted 03 December 2015 - 09:39 PM
ye its a bit heavy on the arms when u do horizontal bits like the bottom of the side windows... i had to hold it upright to get onto the seam properly.
Also it struggles if u have too much weld thru primer ive found that if i coat the inner 2 faces of a seam and keep the outer 2 faces bair metal it welds ok then i prime up the outer 2 faces after,also keep a bit of scotch bright or something simalar handy and clean the tips off every few spots they get clocked up with muck and soot and then the spots arent right.
other than that its great much less work after than plug welding and much quicker 2.
#64 Stu.
Stu.
  • 912 posts
Posted 03 December 2015 - 11:50 PM
I'll be getting one then. Thanks.
#65 feybrand
feybrand
  • 1,247 posts
Posted 04 May 2016 - 04:49 PM
Heello all
Haven't touched this for a while untill this week  just been collecting parts ...so far i have
2 outer sills
2 floor pans
2 steps
2 jacking points
2 door skins
cross member
heelboard
First job i tackled this week was the drivers door skin ..i figured if i line the door up i can work off it for the step.It all came apart nice and easy (sorry no pics) and needed 2 little repairs on the bottom lip which went well i was pretty pleased with the result.
I then fitted the door skin ,a job ive done before however the skins i have are unfortunately magnum panels and it proved very difficult to get a decent fit and ive since noticed that the top lip that the window sits against isnt as well defined as on the original panels,i also have a little issue with the gap down the back edge (where the catch is) and along the curve at the bottom
#66 feybrand
feybrand
  • 1,247 posts
Posted 04 May 2016 - 04:56 PM
I gave up on the door after a while and set about cutting the inner pocket ..cross member...floor and sill off
this highlighted a few other issues with the car ..mainly some old botches that i cant explain,for example theres a 2-3 mm thick girder inside the crossmember despite the crossmember having never rusted or been damaged
it even extends to the jacking point
#67 feybrand
feybrand
  • 1,247 posts
Posted 09 May 2016 - 05:47 PM
So at the end of my first week off of the year i have removed the driverside floor,inner sill,outersill,rear pocket,driverside rear heelboard and the cross member.
The floors not cut out neatly at the moment ive cut out less than i intend to replace so far so that when i line up the new panels i have a little bit of room for error before final fitting.
the new crossmember is lined up and screwed in with self tappers for now so that i can remove it for the final cut on the floor.
The plan is to line up the heelboard repair first using the subframe to get it in the right spot then the floor panel ..step and outer sill ...all lined up and either tacked or screwed in place before i fully weld anything in so that i can make adjustments at any time. woking of the subframe at the back the crossmember in the middle,the front bulkhead at the front and the door for the door step placement .
Quick couple of pictures of my butchery so far.....
View from the rear through where the heel board would normally be
cross member and front floor pan ...or lack of
and finally the view inside the car
Hoping to get out and work on this a lot more often now the weathers warming up ive wasted the last 6 months stuck in the house
#68 feybrand
feybrand
  • 1,247 posts
Posted 01 August 2016 - 06:44 PM
Soooo i didn't have a camera for a while hence no updates but i have still been busy
The driver side floor panel is in as well as the inner and outer sill and the door post and driver side rear bin
pics
front floor
rear floor and rear bin
door step
outer sill
heel board repair
door post
and today i have finished off the last few bits of the inner wing removal and started replacing the little panel that sits behind the damper mount ...i was gonna patch it but i decided to take it off n replace it
this is the one
made up a new panel
then i trial fitted it with an old mount as a guide ...took ages of little tweaks to get this right for such a simple panel that no one will ever see
once i was happy i removed the old panel
painted everything i could reach inside...i also did the same in the sill and door post
and thats the lot lol
it was going well so i thought lets leave it at that before it goes wrong......as it did a few weeks ago when i pressed on and now ive got to redo the drivers door skin..again
havent got any time off now till october so planning to do little jobs untill then when i will start the passenger side
#69 blueovalcraig
blueovalcraig
  • 193 posts
Posted 01 August 2016 - 09:49 PM
Great work mate
#70 Twilton
Twilton
  • 57 posts
Posted 02 August 2016 - 08:38 PM
Very nice man, looking good!
#71 feybrand
feybrand
  • 1,247 posts
Posted 07 August 2016 - 02:55 PM
Small update today ...my grinder packed in halfway thru cleaning off the bulkhead so i primed it up ..the end i needed doing was finished anyway
and then i attached the panel from the other day ...spot welded the front edge and plug welded around the mount holes,with a little seam weld on the back across the top of the block that has the threads in for the damper bracket.
Edited by feybrand, 07 August 2016 - 02:56 PM.
#72 slidehammer
slidehammer
  • 1,154 posts
  • Local Club: LSMOC
Posted 08 August 2016 - 09:26 PM
The bodywork is really starting to come together, keep up the good work.
#73 feybrand
feybrand
  • 1,247 posts
Posted 29 September 2016 - 05:27 PM
soooo just a small update but should be followed by some more ive got a fortnight off work
ive redone the drivers side door skin this time using a genuine panel and the result is much better ...still not quite perfect but thats down to my cheap door step and not the door panel.
i have also started to strip the passenger side door which is pretty much the same condition as the drivers side was
old skin
and a quick few of the rotten lip of the door frame
needs a bit of work but easy salvageable
#74 inkyjamesdee
inkyjamesdee
  • 83 posts
Posted 29 September 2016 - 11:40 PM
Great project and good work looking forward to seeing more. Followed.
#75 ryomini
ryomini
  • 583 posts
Posted 01 October 2016 - 02:22 PM
Yep nice work, a pretty big project you have here
