Types Of Starter Motor!?
7 replies to this topic
#1 jamieburke17
jamieburke17
  • 75 posts
Posted 19 April 2015 - 12:32 PM
Hi, my mini is a 1990 mayfair with a 1994 998 engine, but not for long as im putting a 1380 in it.. hence  i need the sporty clutch and flywheel, but they are described as verto, pre verto pre engaged and inertia, 180mm and 190mm, witch one do i need!? please help!
#2 rocker
rocker
    Just On Tickover
  • 8 posts
Posted 19 April 2015 - 12:36 PM
Doesn't that depend on the age of the engine?
The earlier mini's had pre verto clutches and smaller clutch plates (180mm) and the later minis like the rovers for example, had verto clutches and 190mm plates.
I think that's correct but someone here will be able to help more. Just speaking from experience of my own which is a 1993 1275cc A+
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 April 2015 - 02:48 PM
Correct rocker, what engine are you using A or A+ and are you using your current gearbox assembly or buying new?
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 19 April 2015 - 03:10 PM
Pre verto clutches generally use Inertia type starters,
Verto clutches generally use pre engaged type starters,
I know that the ring gears(verto or pre verto) have different tooth counts, also there is 2 clutch plate sizes too
#5 jamieburke17
jamieburke17
  • 75 posts
Posted 19 April 2015 - 03:12 PM
a+, and no im buying a refurbished gearbox apparently ill need a verto, as the pre vertos got faded out in the early 80s, but will i have a inertia or pre engaged starter? is there any way of telling?
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 19 April 2015 - 03:17 PM
On a 94 car you should have a Verto with a pre engaged stater. The inertia starter  was phased out around 1984 in favour of the pre engaged unit. There was some cross over in 1984 such as on the Mini 25 where there was a verto clutch with an inertia starter.
#7 jamieburke17
jamieburke17
  • 75 posts
Posted 19 April 2015 - 03:21 PM
right  i see, cheers!
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 19 April 2015 - 03:23 PM
Indeed, a friend has one of these engines, very annoying to work on,
A 1990 onwads casr is indeed Pre engaged(solinoid on starter instead of on the inner wing)
