Last season I had an electrical problem with '68 Mini where turning on the wipers while the engine was running caused the engine to die. The wipers worked fine when the engine was off, and the engine ran fine while the wipers were off. I started trouble shooting the problem in the fall by running a new wire directly from the fuse box to the coil and replacing the coil. Neither of which made a difference.
Over the winter I removed the wiper motor from the car and gave it a thorough cleaning / de-greasing in the warmth of my basement workshop. Now that spring is finally here I started looking for wiring issues in the car. Initially I didn't find anything but a little bit of insulation missing at the base of a connector on a 12 volt lead at the wiper motor. I was planning to cut off the old connector and crimp on a new one. However, when I removed the electrical tape from several inches of the wiring harness I found melted insulation and bare copper wire. This continued over most of the wire all the way to the dashboard switch. Then I traced a different lead from the dash switch that disappeared into the wiring harness and found more melted insulation and bare copper. Finally I traced the black wire from the switch and found an inch of melted insulation near the bullet connector where it plugged into the harness.
The wiper rack is difficult to move by hand and needs a good clean, lube and adjustment. I believe the wiper motor was drawing too many amps causing the wires to heat up and melt the insulation. The good news is I did not find any other damaged wires adjacent to the wiper wiring. I had to remove a lot of electrical and friction tape from the harness to be sure, but this was time well spent.
Like all Mk1 and Mk2 Minis, my car only has two circuits each protected by a 35 amp fuse. I plan to install a separate in-line fuse on the 12v lead to the wiper motor. What amp fuse should I use to protect against this problem recurring?
Thanks,
David Schwartz
