Hi guys,
July is quickly coming and its the time I have put aside to pull the engine out my mpi and do a rebuild on the gearbox and hopefully give the engine a refurb.
guessworks has kindly pointed me in the right direction for the gearbox but im still a bit unsure for the engine rebuild on what I should be changing. I have done quite a bit of research and im pretty confident in my abilities to what needs to be done but I have a few questions that hopefully some of you can answer.
Firstly what I want to know is can I just renew the crank bearings and big end bearings and thrust washers. I am not having any machining done as unfortunately there is no one in jersey to do it. Im also on a budget.
At the moment im looking at doing as follows
leaving the head (it was new and fitted 3 months ago)
rebuilding the gearbox with guessworks kit, changing the final drive to 3.2
new cam/plus followers
new simplex timing chan
new turbo clutch and lightened flywheel (courtesy of AC)
new forged 1:4 roller rockers
new oil galleys????
new main bearings???
new big end bearings??
which ones do I order just standard???
new piston rings?
engine gasket kit and spare shims(mainly for gearbox)
on top of this does anyone know of any MPI related things that I need to order separately?
im also wondering what the grey paste is minimania and bill sollis both used to grease the washes???
basically im getting together a price list and working out my budget.
thanks for the help and no doubt there will be some more questions but for the mean time thanks in advance.
