Hey all,
Currently in the process of replacing thermostat and coolant bits and bobs,
Had a mate over the other night and when removing the thermostat housing he sheared one of the studs off!
It managed to snap off completely flush with the top of the head and there is no chance of manageing to get it out easily.
The stud that is snapped it the one of the right hand side that is also used for the radiator mounting. The other 2 studs are fine and ill be able to get a nice tight grip on the thermostat housing with them.
Now here is the stupid question but it got me thinking.....
Would just them 2 studs be enough to stop the housing from leaking coolant everywhere? Was going to put some liquid gasket sealant around it to help with a nice seal but would it be okay with just the 2 studs rather than the intended 3?
Failing the above any ideas on how to get the remains of the stud out? There is pretty much nothing to get hold of to remove it. Would it be okay to drill it out?
Don't be too mean with your responses, its an idea that popped into my head.
Much ta
Matt
Edited by matt050990, 16 April 2015 - 09:33 AM.
