Z Car Vtec Build
161 replies to this topic
#91 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 03 April 2016 - 08:18 PM
got a few thing finalised with there positioned
26213517825_544ac04a3d_k.jpgUntitled by william woodhouse, on Flickr
26147181641_0fb8ec6e60_k.jpgUntitled by william woodhouse, on Flickr
got the wholes cut in the bulkhead for the ecu plugs and the chassis loom
25940628990_736999996f_k.jpgUntitled by william woodhouse, on Flickr
26213425125_024e465beb_k.jpgUntitled by william woodhouse, on Flickr
made up a bracket for the jumper pack points
25608282024_2c3d00841a_k.jpgUntitled by william woodhouse, on Flickr
bracket cut out ready to be folded
25940543220_c22f425b26_k.jpgUntitled by william woodhouse, on Flickr
26146436141_02592623d9_k.jpgUntitled by william woodhouse, on Flickr
26213316035_fb3d753921_k.jpgUntitled by william woodhouse, on Flickr
25939976880_f1ad8ff5b1_k.jpgUntitled by william woodhouse, on Flickr
folded
26186835266_1dd6f77f32_k.jpgUntitled by william woodhouse, on Flickr
25939851190_b5b9a326e7_k.jpgUntitled by william woodhouse, on Flickr
25612868403_370ed6b955_k.jpgUntitled by william woodhouse, on Flickr
cleaned up and ready to go in
25612892203_7a6c3d2e45_k.jpgUntitled by william woodhouse, on Flickr
in the car needed to do a little mod so i could get to do it up
25942537370_f4a000c110_k.jpgUntitled by william woodhouse, on Flickr
25942503030_11b246d523_k.jpgUntitled by william woodhouse, on Flickr
with the mod done
25942493480_3f71828cdb_k.jpgUntitled by william woodhouse, on Flickr
26149076941_fe175fdabf_k.jpgUntitled by william woodhouse, on Flickr
25612711743_7e08af9c6d_k.jpgUntitled by william woodhouse, on Flickr
making the holes for the all the lines to run through
25942505020_8c0f30fe12_k.jpgUntitled by william woodhouse, on Flickr
26149070861_2bf396f4f1_k.jpgUntitled by william woodhouse, on Flickr
in the car
25610603994_f4aa7fdcd8_k.jpgUntitled by william woodhouse, on Flickr
getting the centre console finished
26147686501_cefce62497_k.jpgUntitled by william woodhouse, on Flickr
25610603044_ba178b48ba_k.jpgUntitled by william woodhouse, on Flickr
25611332163_64c22e8946_k.jpgUntitled by william woodhouse, on Flickr
 got the battery cut off in
25609221804_231d90c2ef_z.jpgUntitled by william woodhouse, on Flickr
25941106580_42abfc2229_z.jpgUntitled by william woodhouse, on Flickr
the battery tray is secured
gave the inside a clean out was getting a bit messy
26187591366_43e43df583_z.jpgUntitled by william woodhouse, on Flickr
25608708314_047939cf16_z.jpgUntitled by william woodhouse, on Flickr
centre console back in
25608643594_4565f5dc73_z.jpgUntitled by william woodhouse, on Flickr
26120954242_264f400cbf_z.jpgUntitled by william woodhouse, on Flickr
gear linkage is in
26213418825_4b004f1c8d_z.jpgUntitled by william woodhouse, on Flickr
a few bits to sort on this to get the gear linkage working smoothly but can get all gears which is good
has anyone got any wildwood front brake flexi lines for sale? if so could you inbox me a price thanks
#92 Luigi33
Luigi33
  • 79 posts
Posted 03 April 2016 - 08:25 PM
What is the postive/negative stud for - jump start?
#93 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 03 April 2016 - 08:37 PM
Ye so you can hook up a jumper pack without having to take the seat out to get to the battery
Edited by BLING BLING WHEELZ, 03 April 2016 - 08:37 PM.
#94 Luigi33
Luigi33
  • 79 posts
Posted 03 April 2016 - 09:00 PM
I hadn't thought of that issue yet good point!
​Got a Odyssey in my garage from the old car waiting to go on there so usually don't get too much trouble but taking seat out would not be fun
#95 andream88
andream88
  • 169 posts
Posted 04 April 2016 - 04:02 PM
Why did you put the battery behind the seat instead of at the front of the car?
Keep up the good work by the way
#96 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 04 April 2016 - 04:59 PM
Tried to put it at the front of the car but it wouldnt fit
I fitted the fuel tank before i got the battery and didnt leave enough room
#97 Luigi33
Luigi33
  • 79 posts
Posted 04 April 2016 - 08:52 PM
There was no room in front of mine either
#98 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 10 April 2016 - 08:30 PM
got all my brake lines thought this week, from a company called exact engineering would recommend them next day delivery they use to supply z cars with all the lines so have most of the lengths and ends on drawing  ready to make and send out
all the stuff for front brakes rear brakes and the stuff to make the clutch line
26351920935_b30d64e4c7_k.jpgUntitled by william woodhouse, on Flickr
26286210401_fb16b47e5f_k.jpgUntitled by william woodhouse, on Flickr
25747037304_ecfa41ac61_k.jpgUntitled by william woodhouse, on Flickr
25749690863_529f47b663_k.jpgUntitled by william woodhouse, on Flickr
fitting the brake lines
securing the the rear lines to the radius arms
26259487272_51336836d9_k.jpgUntitled by william woodhouse, on Flickr
26325760506_d244103f89_k.jpgUntitled by william woodhouse, on Flickr
25747551614_6cd1e7910f_k.jpgUntitled by william woodhouse, on Flickr
26259509112_f589c7d5c3_z.jpgUntitled by william woodhouse, on Flickr
running the lines to the pedal box
26352407175_be0d84a9fa_k.jpgUntitled by william woodhouse, on Flickr
26079028330_e170fccab7_z.jpgUntitled by william woodhouse, on Flickr
25747551704_0dc4421d43_k.jpgUntitled by william woodhouse, on Flickr
now the lighter evenings are here am going to try doing a few more bits in the evening after work
#99 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 17 April 2016 - 08:27 PM
rear brake lines and clutch lines are all connected and in
26414227791_17729087fd_z.jpgUntitled by william woodhouse, on Flickr
26388052332_f52d64c852_z.jpgUntitled by william woodhouse, on Flickr
all properly run and secured into position
bulkhead plate back in with grommets
25881304313_6b088cb00f_z.jpgUntitled by william woodhouse, on Flickr
break line t piece secured
26414244391_37657b3366_z.jpgUntitled by william woodhouse, on Flickr
25875491454_269620dd93_z.jpgUntitled by william woodhouse, on Flickr
 from inside the cab
25875502634_0f75977c3d_z.jpgUntitled by william woodhouse, on Flickr
clutch line is in
26454443826_39e9401e68_z.jpgUntitled by william woodhouse, on Flickr
#100 andream88
andream88
  • 169 posts
Posted 18 April 2016 - 09:31 AM
Great job!!!!
#101 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 18 April 2016 - 11:48 PM
Is it sufficient to just leave the bottom open for cooling (yes I realize the rad is in the front) or will you need to have some vents in the sides to augment airflow? Will you need to panel under the engine for aero or just leave it all open? What about vents in the boot lid? I'm considering building a rear engined Mini too, hence the questions.....
#102 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 19 April 2016 - 07:51 PM
I was going to maybe put some discreet holes behind the number plate in the boot then space the number plate to allow air flow, am going to put some holes in the rear valence by the Exhaust as well
Was going to run opening and closing rear quatre light windows so can open these for more air flow but wasnt going to put a skid pan on the under side
Edited by BLING BLING WHEELZ, 19 April 2016 - 07:54 PM.
#103 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 27 April 2016 - 08:10 PM
battery cable run for the fuze box power
all the break/ clutch lines are secured
26020747273_4fe2bac880_k.jpgUntitled by william woodhouse, on Flickr
26350582980_92af4f2b8a_k.jpgUntitled by william woodhouse, on Flickr
26350670630_47bf3184d2_k.jpgUntitled by william woodhouse, on Flickr
26558601251_1f93bb7de6_k.jpgUntitled by william woodhouse, on Flickr
26018089704_dbaa3aa128_k.jpgUntitled by william woodhouse, on Flickr
26018082834_3c89c3ae61_k.jpgUntitled by william woodhouse, on Flickr
26017923554_d45272b7d6_k.jpgUntitled by william woodhouse, on Flickr
26351201470_9106164883_k.jpgUntitled by william woodhouse, on Flickr
got all the switches through
26021197713_010a2f4139_k.jpgUntitled by william woodhouse, on Flickr
26018742714_f0315ebc09_k.jpgUntitled by william woodhouse, on Flickr
26351135430_c6eec7fc99_k.jpgUntitled by william woodhouse, on Flickr
fitting the switches into the panel
26018504404_3af72be45f_k.jpgUntitled by william woodhouse, on Flickr
26350886860_3e5ba99c42_k.jpgUntitled by william woodhouse, on Flickr
26350920570_f112abfc9a_k.jpgUntitled by william woodhouse, on Flickr
wiring in the alternator and starter motor
26351164070_4fd7766611_k.jpgUntitled by william woodhouse, on Flickr
26531432172_bd949470e1_k.jpgUntitled by william woodhouse, on Flickr
26559011841_01b1f677e7_k.jpgUntitled by william woodhouse, on Flickr
i taped a piece of tig wire into the cable so i could bend it into shape
26018587164_142a8caee9_k.jpgUntitled by william woodhouse, on Flickr
26624257585_2714f8340d_k.jpgUntitled by william woodhouse, on Flickr
re wrapped in red
26624188135_0fa92de49f_z.jpgUntitled by william woodhouse, on Flickr
26624208325_b1f1d39a9d_z.jpgUntitled by william woodhouse, on Flickr
26350729350_ebf129a116_z.jpgUntitled by william woodhouse, on Flickr
engine earth
26558898901_64bd416463_z.jpgUntitled by william woodhouse, on Flickr
wiring in the battery jumpers
26018418924_9560e6ca02_z.jpgUntitled by william woodhouse, on Flickr
26624080025_e5dee8f9b5_z.jpgUntitled by william woodhouse, on Flickr
26018159364_1f0fbee836_z.jpgUntitled by william woodhouse, on Flickr
26597803256_233088f6e2_z.jpgUntitled by william woodhouse, on Flickr
yet to finish this should get it done over the bank holiday
#104 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 29 April 2016 - 11:49 AM
Top work there Will.
#105 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 10 May 2016 - 08:36 PM
got the battery for all wired up with the anderson quick release system
26938124455_afe1e59de8_k.jpgUntitled by william woodhouse, on Flickr
26664689920_bb8b2318f7_k.jpgUntitled by william woodhouse, on Flickr
26938074585_bee0d82770_k.jpgUntitled by william woodhouse, on Flickr
26332416134_1d560b1535_k.jpgUntitled by william woodhouse, on Flickr
26843677132_f069d7b0ad_k.jpgUntitled by william woodhouse, on Flickr
battery all connected with the quick release system
26843674702_1ca533d607_k.jpgUntitled by william woodhouse, on Flickr
26938051245_eb8fe1e16c_k.jpgUntitled by william woodhouse, on Flickr
26869962351_25fc4fbfcb_k.jpgUntitled by william woodhouse, on Flickr
running the battery lines to the cut off
26938906625_ba32cdb176_k.jpgUntitled by william woodhouse, on Flickr
26938845735_98cee56d75_k.jpgUntitled by william woodhouse, on Flickr
26334162513_b9b24799e2_k.jpgUntitled by william woodhouse, on Flickr
26665401880_dee075b96e_k.jpgUntitled by william woodhouse, on Flickr
26332906544_bad7b704ef_k.jpgUntitled by william woodhouse, on Flickr
26938534115_df5fbaf23c_k.jpgUntitled by william woodhouse, on Flickr
26333910323_256098a534_k.jpgUntitled by william woodhouse, on Flickr
26664963370_513e15814b_k.jpgUntitled by william woodhouse, on Flickr
26938288125_9a3f986c26_k.jpgUntitled by william woodhouse, on Flickr
26332494204_a500685984_k.jpgUntitled by william woodhouse, on Flickr
hand break cable is in
had to modify the hand break bracket to meet up with the hand break
26664803400_9ce0c2263d_z.jpgUntitled by william woodhouse, on Flickr
26904371476_41607db79f_z.jpgUntitled by william woodhouse, on Flickr
26904367746_a546d8c7fb_z.jpgUntitled by william woodhouse, on Flickr
26664643870_1277b7633c_k.jpgUntitled by william woodhouse, on Flickr
26938049655_8ded54e433_k.jpgUntitled by william woodhouse, on Flickr
26664636720_e0baaf3549_k.jpgUntitled by william woodhouse, on Flickr
26938045425_f5a715239a_k.jpgUntitled by william woodhouse, on Flickr
next thing is to get the fire extinguisher in and all the pull cords
