Z Car Vtec Build
161 replies to this topic
#46 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 16 September 2015 - 05:28 PM
Gee, I wonder who came up with idea about 5 years ago???? I really should start patenting these ideas
Lol was reading through your build thread and noticed the wireless buttons did abit of googleing and found the raptor
#47 andream88
andream88
  • 169 posts
Posted 16 September 2015 - 06:21 PM
At 600£ each you would have made quite a few quids mate...
#48 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 24 September 2015 - 07:18 PM
quick update seats, column in and centre console
21358265788_ea08bf504b_k.jpgUntitled by william woodhouse, on Flickr
21519905586_068033857d_k.jpgUntitled by william woodhouse, on Flickr
my removable centre console mounts
21358268788_06d292acf8_k.jpgUntitled by william woodhouse, on Flickr
21359218509_8cac86197e_k.jpgUntitled by william woodhouse, on Flickr
theres about 5mm clearance on both sides if the seats
lifeline boss welded on
20952492044_25df0adf3c_k.jpgUntitled by william woodhouse, on Flickr
21574953045_b4c3c8088b_k.jpgUntitled by william woodhouse, on Flickr
21548744746_1710352fdc_k.jpgUntitled by william woodhouse, on Flickr
you can see how close it is to the frame in this one
21386540690_805b9d990a_k.jpgUntitled by william woodhouse, on Flickr
21387922029_63839ca5c5_k.jpgUntitled by william woodhouse, on Flickr
should get the 6 point omp harnesses and the other seat soon
#49 andream88
andream88
  • 169 posts
Posted 24 September 2015 - 11:40 PM
Weld that centre console to the shell mate!!
It saved my legs in the accident!!
The mini floor is soft as butter and in case of a front crash there is nothing to stop the front subframe from getting inside the car!!
#50 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 25 September 2015 - 06:35 AM
Ok thanks
#51 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 25 October 2015 - 03:05 PM
so last post the seat was fitted, a few more pics of the seat mount i made, the 6 point harness is in know as well
22356263922_0bf5e57441_k.jpgUntitled by william woodhouse, on Flickr
22369322655_f0eeab0449_k.jpgUntitled by william woodhouse, on Flickr
six point harness
22366272495_b422899121_k.jpgUntitled by william woodhouse, on Flickr
22340257476_e42c79f001_k.jpgUntitled by william woodhouse, on Flickr
22179024939_9a5b6a81c4_k.jpgUntitled by william woodhouse, on Flickr
the six point harness mounts
22356237412_8fb5f91bf2_k.jpgUntitled by william woodhouse, on Flickr
 got the valence exit exhaust through
21747866864_0fe7cdfbf8_k.jpgUntitled by william woodhouse, on Flickr
22370630555_28425f76a6_k.jpgUntitled by william woodhouse, on Flickr
22182661390_ea82c7bd6a_k.jpgUntitled by william woodhouse, on Flickr
rear valence is on had to modify it were it mounts behind the whees to get clearance
21747313054_276aba0917_k.jpgUntitled by william woodhouse, on Flickr
#52 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 25 October 2015 - 03:12 PM
bulkhead is in
22356995422_f0271c5021_k.jpgUntitled by william woodhouse, on Flickr
22182110358_d9dc471993_k.jpgUntitled by william woodhouse, on Flickr
22380554981_f53ac5b35c_k.jpgUntitled by william woodhouse, on Flickr
fitted with nut sirts into the frame
22181421970_3c5d0603ea_k.jpgUntitled by william woodhouse, on Flickr
last thing to do is to cut out were the raised tunnel is and make up a separate plate to run the lines through. so if i need to work on it in the future i will not need to drain the systems down.
21746451104_f024c074c5_k.jpgUntitled by william woodhouse, on Flickr
#53 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 25 October 2015 - 03:22 PM
front end sorted
21746483874_84e083431c_k.jpgUntitled by william woodhouse, on Flickr
21746445954_f8a920f085_k.jpgUntitled by william woodhouse, on Flickr
a few more shiny bits front demon tweeks
22352865972_ba91f36472_k.jpgUntitled by william woodhouse, on Flickr
22178226058_d8c295461d_k.jpgUntitled by william woodhouse, on Flickr
heat shrink for the wiring to come ):
22339854706_a7ce04c947_k.jpgUntitled by william woodhouse, on Flickr
battery clamp
22178167420_a2360337de_k.jpgUntitled by william woodhouse, on Flickr
harness cutters and glass hammer
22365934195_9bd5dd2714_k.jpgUntitled by william woodhouse, on Flickr
steering wheel hook and for the omp head seats
K&N apollo induction kit
22178189188_ce41b2039a_k.jpgUntitled by william woodhouse, on Flickr
fan kit
22178243348_41395a3397_k.jpgUntitled by william woodhouse, on Flickr
last seat through with help from the dogs teddy
22181315560_5ea8e97d04_k.jpgUntitled by william woodhouse, on Flickr
#54 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 26 October 2015 - 04:23 PM
Looking Good, keep it up......
#55 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 26 October 2015 - 04:45 PM
Is this the car previously know as Pinkie?  The one that had the wire wheels and hydraulics?  Great build so far!
#56 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 26 October 2015 - 06:03 PM
No i do not think so as it was sat in a garden for quite a few years, it was the lady i bought it off. First car.
I have seen pics of that mini is very cool
#57 cptkirk
cptkirk
  • 1,799 posts
Posted 26 October 2015 - 08:06 PM
A bit of advice - try and make the bulkhead as air tight as possible as you will get fumes in the cabin if it is not.......to help with keeping fumes out of the cabin use some form of fresh air in, whether that includes a heater matrix is up to you. This will create a positive pressure within the cabin that will push the air out of the little holes that are left in the bulkhead sealing. On the subject of a heater matrix I don't have one, I used a heated screen instead, in the winter its cold for the first 20mins or so but once its heat soaked you don't need blown hot air in the cabin.
#58 BLING BLING WHEELZ
BLING BLING WHEELZ
  • 170 posts
Posted 30 October 2015 - 07:05 PM
Will do a bit of research on solutions thanks
Do you think mounting fans in the cab to blow air into the bay would solve this? What have you done to solve this? any pic would help
#59 FlyingScot
FlyingScot
  • 2,676 posts
Posted 30 October 2015 - 07:24 PM
Epic build, looks great. Looking forward to seeing it finished.
FS
#60 dondo
dondo
  • 128 posts
Posted 31 October 2015 - 05:26 PM
FS
Another thumbs up on this build from another Scot !!
