Hi forum,
Went to Halfords yesterday for a free battery check as it seemed as though I couldn't have the lights on for ten minutes after having stopped before the battery went flat. They told me the battery itself was ok (78% healthy), so it must be the alternator itself or a loose belt as there was a lack of voltage going back in.
I came home and checked the belt itself and there is definitely no play in that - used the basic 90 degree twist check. I understand that commonly the earthing points can get corroded, particularly the one in the engine bay, attached to the steady arm. Having checked the negative lead coming off the battery in the boot and finding it all fine, I thought I may as well replace the earth strap in the engine bay and even add a second strap as recommended to see if that cures the issue. Unfortunately, I don't have a multi-meter to check voltage of the alternator, so I'm sort of doing this by braille.
Question is, considering pretty much everyone says that the braided cables like the standard included one are rubbish, can I (and should I) actually replace this with a covered cable like this one:
http://www.halfords....ry-cable-22cm-9
I know this is designed for the negative terminal of the battery, so would the gauge of the wire be an issue here? Is there a reason why they use the braided cables for this rather than something a bit more substantial?
Jacob
