'89 Mini City To 'mk1 Cooper S'
617 replies to this topic
#526 johnR
johnR
  • 2,302 posts
Posted 16 November 2021 - 11:08 PM
that gearbox looks ace! One tip I would suggest is to pop the bolt for the gearstick steady bar in now. I forgot to do mine when it was off the car and had to take the exhaust off to give me enough clearance to slide it in!
Thanks, the bolt is still on the 998 in the car atm, but I've not had any problem with that before - maybe a different exhaust?
#527 jamesquintin
jamesquintin
  • 1,017 posts
Posted 17 November 2021 - 04:06 PM
Ahh, ok yeah, this was on my MPI with the factory double downpipe
Q
#528 johnR
johnR
  • 2,302 posts
Posted 17 November 2021 - 05:27 PM
A plan for a roadtrip has been suggested by a friend: through France (& Switzerland?) to Italy, down the East coast to Ancona where we will take the overnight ferry to Greece, stay a while, then back up through the Balkans, Austria, Germany and home. I feel a roofrack would be useful for a trip of this length and MrBridgers seems the obvious choice of supplier but for my taste their Original Monte is a little small and the Monte Max a little large. I've been in touch and asked for a custom one which splits the difference at around 600mm long which they've kindly agreed to make for me.
#529 johnR
johnR
  • 2,302 posts
Posted 11 January 2022 - 06:42 PM
Shiny parts newly zinc plated ready for HS4 re-builds
#530 johnR
johnR
  • 2,302 posts
Posted 25 January 2022 - 10:21 PM
After a fair bit of head scratching i've worked out where all the parts go and re-assembled these big boys with service kits. Just need some new studs to bolt them to the manifold and some HS4 backplates for my K&N cones to finish.
#531 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 26 January 2022 - 08:28 PM
They look really nice now! Is there much left to do on the engine now?
#532 johnR
johnR
  • 2,302 posts
Posted 26 January 2022 - 11:15 PM
Not too much - I need to get the 998 out of the car and swap some of the common parts over to the 'new' one (flywheel, starter, alternator etc) then once the fried wiring is replaced  it can go in.
#533 johnR
johnR
  • 2,302 posts
Posted 30 January 2022 - 02:14 PM
Four new studs arrived in the post so I tried fitting the carbs to the manifold only to find that the holes for two of the studs had been drilled at an angle and one of those was out of position which means the connection rods don't line up!
I suppose I'll have to have the holes welded up and re-drilled at the right angle and in the right position. never straightforward is it?!!!
#534 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,040 posts
Posted 30 January 2022 - 03:01 PM
If theres enough material around the hole, you could get a machine shop to fit a hell-coil or make a bit with thread on the outside and inside to screw in.
Edited by alex-95, 30 January 2022 - 03:02 PM.
#535 johnR
johnR
  • 2,302 posts
Posted 30 January 2022 - 05:06 PM
Yes, I have used helicoils before - one of the holes probably could be saved using that but the one in the wrong place is too far out so I might as well get them both done properly while I'm at it.
#536 johnR
johnR
  • 2,302 posts
Posted 08 February 2022 - 04:21 PM
I've had the random HS4 stud holes tig welded up and I've linished them back ready for drilling new ones
#537 johnR
johnR
  • 2,302 posts
Posted 08 February 2022 - 09:01 PM
Manifold drilled and tapped, new studs shortened and threads cut further down them. I now need to cut the HS2 linkage bars down to fit between these bigger carbs.
#538 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 08 February 2022 - 11:03 PM
Looking good there! Are you planning on using the PCV on the manifold or the CCV ports on the carbs?
#539 johnR
johnR
  • 2,302 posts
Posted 09 February 2022 - 02:30 PM
On my HS2s I used the ports on the carbs so I guess I'll do the same.
#540 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 14 February 2022 - 03:13 AM
Ok that’s good, I always found that was the easiest way to do it.
