'89 Mini City To 'mk1 Cooper S'
617 replies to this topic
#391 johnR
johnR
  • 2,295 posts
Posted 18 April 2020 - 11:53 AM
Gathered all the parts ready to go back on - exhaust headers have been painted as have the heater side panel and 2nd head steady
#392 johnR
johnR
  • 2,295 posts
Posted 22 April 2020 - 02:09 PM
So I got the engine back in without too much hassle - the usual pain to get the engine mounts to subframe bolts in but done. Whilst fiddling around with the fan belt however I notice that the timing plate? on the crank damper has come away somehow and is rattling around between the damper and timing cover. This means the engine will have to come out again. Aaaaargh!
#393 johnR
johnR
  • 2,295 posts
Posted 04 May 2020 - 05:26 PM
Engine out again
...and offending loose ring removed and binned.
#394 MaximMini
MaximMini
  • 226 posts
Posted 05 May 2020 - 06:25 AM
Hi John,
Do you know what the purpose of this ring is?
Cheers,
Christian
Edited by MaximMini, 05 May 2020 - 06:26 AM.
#395 johnR
johnR
  • 2,295 posts
Posted 05 May 2020 - 11:28 AM
To annoy me :D
#396 MaximMini
MaximMini
  • 226 posts
Posted 08 May 2020 - 09:28 AM
Successfully I guess ..
#397 johnR
johnR
  • 2,295 posts
Posted 10 May 2020 - 04:47 PM
Damper (and starter motor) re-painted so engine ready to go back in.
#398 Junior Mini
Junior Mini
  • 313 posts
Posted 10 May 2020 - 09:33 PM
Looking good ?
#399 johnR
johnR
  • 2,295 posts
Posted 10 May 2020 - 09:38 PM
Thanks, I'll be happier when it runs as well as it looks!
#400 johnR
johnR
  • 2,295 posts
Posted 12 May 2020 - 07:13 PM
made good progress today - engine in, only carbs, head steady, exhaust and heater to go
#401 timmy850
timmy850
  • 3,295 posts
  • Local Club: MITG
Posted 12 May 2020 - 11:15 PM
Nice work !
#402 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 13 May 2020 - 05:12 PM
excellent your almost ready to go for a blast
#403 johnR
johnR
  • 2,295 posts
Posted 13 May 2020 - 09:44 PM
Yes, nearly: - I re-fitted the exhaust today and ordered a Bosch blue coil. This is the coil recommended by 123 for use with my dizzy, so should eliminate the coil as the cause of the motor cutting-out at higher revs.
Now I need to fit the carbs, bleed the brakes and cross my fingers!
#404 johnR
johnR
  • 2,295 posts
Posted 15 May 2020 - 04:54 PM
Brakes bled, carbs in place - just need bolting down. Now need to sort the heater before I refill it with coolant.
#405 johnR
johnR
  • 2,295 posts
Posted 16 May 2020 - 03:19 PM
Frustrating day today - I bolted the carbs on, unbolted them because I'd put the throttle quadrant the wrong way up, bolted them back on, tried to fit the 2nd head-steady to find that the carbs heatshield stops access to the exhaust manifold stud that is one of the steady's mounting points so will need to take them off again. Then I couldn't find one of the heady steady rubbers that I had earlier so commenced a search of the garage to no avail. Went back to have another go at the stud and dropped it into the engine bay. It didn't reappear underneath so jacked the car up to have a good poke around - no sign of it. Eventually I found the stud hiding behind the lost steady rubber on top of the subframe. the stud had jammed itself between the subframe tower and the body and took the best part of half an hour to recover, at which point I gave up!
