'89 Mini City To 'mk1 Cooper S'
617 replies to this topic
#271 johnR
johnR
  • 2,295 posts
Posted 10 June 2018 - 12:41 PM
Thanks, I've tried satin black and BMC green on other covers so thought I'd give this a try
#272 johnR
johnR
  • 2,295 posts
Posted 12 June 2018 - 09:11 PM
I think the front cones should have settled enough now - I'd better adjust the rear HiLo's up a bit to level it out
#273 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 13 June 2018 - 05:38 AM
Little Stunner!
#274 johnR
johnR
  • 2,295 posts
Posted 01 August 2018 - 06:47 PM
A few more parts added - K&N cones as you can see, an Austin rocker cover plate - I want to get some copper rivets to secure the two plates, and the distributor housing 'O' ring.
Edited by johnR, 02 August 2018 - 09:17 AM.
#275 johnR
johnR
  • 2,295 posts
Posted 08 August 2018 - 05:16 PM
Today I picked up my alternator bracket which has been lightened/aesthetically improved by having four holes milled through it. Now it needs polishing and re-chroming. Also the copper rivets for the Austin and Westlake rocker cover plates arrived - awaiting the setting tool.
#276 johnR
johnR
  • 2,295 posts
Posted 09 August 2018 - 08:17 AM
I received some pictures from a previous owner today dated from 1997 when the car had been resprayed from it's original white.
#277 Vinay-RS
Vinay-RS
  • 2,112 posts
Posted 09 August 2018 - 10:05 AM
Wow, that is a hectic transformation, I wonder if there are before/after picture threads on the forum.
#278 johnR
johnR
  • 2,295 posts
Posted 10 August 2018 - 04:01 PM
Another small detail job today - I drilled out stubs of the old rivets with the help of a right angle drill adaptor and fitted my new original engine number.
The platers are going to collect the alternator bracket on Thursday for re-chroming so I ground and polished the superfluous lumps and bumps off it so it's ready to go.
Edited by johnR, 10 August 2018 - 04:02 PM.
#279 johnR
johnR
  • 2,295 posts
Posted 17 August 2018 - 05:08 PM
The setting tool for the copper rivets arrived yesterday - I ground it back a little so it wouldn't mark the rocker plates and shortened the rivets a little after a trial one bent over rather than deforming evenly.
Even so typically the first one didn't go to plan - partly because the raised panel on the rocker cover isn't quite flat and partly because our technique needed adjusting it skewed and deformed the Austin plate around the rivet so I'll have to get a new plate and try again. The remaining rivets were perfect.Grrr!
Edited by johnR, 17 August 2018 - 05:10 PM.
#280 johnR
johnR
  • 2,295 posts
Posted 19 August 2018 - 02:58 PM
Good question - if not perhaps there ought to be!
#281 johnR
johnR
  • 2,295 posts
Posted 01 September 2018 - 03:40 PM
A new speedo to fit, ready to better reflect the capabilities of the bigger engine
#282 johnR
johnR
  • 2,295 posts
Posted 06 September 2018 - 09:01 AM
My alternator bracket has been returned and I'm very pleased with it! Great service from Dorsetware metal platers of Poole: collected, stripped, polished and re-chromed and delivered back to my door for £10.
#283 johnR
johnR
  • 2,295 posts
Posted 30 September 2018 - 06:43 PM
The tax has run out today - the signal to start stripping the parts I need from the 998 to complete the 1275 - starter, oil pipe, temp senders, engine mounts and steady bars etc.
#284 johnR
johnR
  • 2,295 posts
Posted 04 October 2018 - 01:40 PM
The engine bay starting to look rather sad as parts come out of here..
.....to go on here.
#285 johnR
johnR
  • 2,295 posts
Posted 06 October 2018 - 09:42 AM
New speedo fitted and the engine crane I'm going to borrow is ready for collection!
Need to remove the brake servo and master and the carb and we're ready to levitate.
