'89 Mini City To 'mk1 Cooper S'
617 replies to this topic
#166 johnR
johnR
  • 2,325 posts
Posted 05 July 2016 - 10:00 AM
Plates painted and drilled - I'm pleased with the result - I think they suit the look of the car much better.
I've also got an RAC stamped alloy GB plate that I think I'll mount to the side of the number plate on an horizontal flat bar using the plate bolts to secure it as I'm reluctant to drill the bootlid.015_zpsmktuadqe.jpg
#167 CobraV8
CobraV8
  • 991 posts
Posted 05 July 2016 - 10:59 AM
Awesome car, nice to see someone with patience to finish things so nicely. I always rush to get things done.
See my signature for my mk1alike project too.
#168 johnR
johnR
  • 2,325 posts
Posted 05 July 2016 - 01:43 PM
Thanks, nice little racer you've built.   What Cobra is that? - I sold my Southern Roadcraft SRV8 to make room for the Mini project
Edited by johnR, 05 July 2016 - 01:44 PM.
#169 CobraV8
CobraV8
  • 991 posts
Posted 07 July 2016 - 10:19 AM
The Cobra is a replica built by Almac in New Zealand. Kevlar body, Big Block Chev race motor. Built in 1989.
#170 johnR
johnR
  • 2,325 posts
Posted 07 July 2016 - 07:08 PM
Quite early for a rep - sounds like quite a beast - any pics?
John
#171 johnR
johnR
  • 2,325 posts
Posted 07 July 2016 - 07:14 PM
Sorted out why I had no lights at all today - loose connector on the toggle switch and finished off the new numberplates and GB badge
#172 86mayfair
86mayfair
  • 557 posts
Posted 10 July 2016 - 04:08 PM
That rear end looks so similar to my own, except I have mk2 lights and a later boot lid. Even the fog lamp mounted in the same place under the bumper
#173 johnR
johnR
  • 2,325 posts
Posted 11 July 2016 - 07:13 AM
Pic?
JohnR
#174 johnR
johnR
  • 2,325 posts
Posted 11 July 2016 - 07:57 AM
Excellent, this is something I really want to do once mine is on the road.  Ideally for my 30th next June but whether my mini will be ready by then is another question altogether :s  Youve done a great job of the car too...well done :)
Did you make it?
JohnR
#175 86mayfair
86mayfair
  • 557 posts
Posted 11 July 2016 - 03:21 PM
Pic?
JohnR
I'm now realising I don't have any pics from the last few weeks, I'll take one and post it
#176 johnR
johnR
  • 2,325 posts
Posted 11 July 2016 - 04:50 PM
Edited by johnR, 20 March 2017 - 01:40 PM.
#177 CobraV8
CobraV8
  • 991 posts
Posted 11 July 2016 - 08:08 PM
John
Yes older now than the original was at the time created. Probably could have bought a real one back then for similar money.
Have a look at the leadfoot link in my signature, lots of photos.
#178 johnR
johnR
  • 2,325 posts
Posted 12 March 2017 - 06:02 PM
Phase 2 - 1275 power! The (loose) plan is to have the 12g940 big valve head ported a little, a fast road cam and maybe an Aldon dizzy together with stage 1 exhaust.
A quick tot up of missing and new uprated parts (excluding carbs and any new bearings etc) is £1300. For now I'll just strip it and re-furbish the covers and ancillaries  1275b_zpsgulxdrbh.jpg
Edited by johnR, 20 March 2017 - 01:35 PM.
#179 johnR
johnR
  • 2,325 posts
Posted 12 March 2017 - 06:04 PM
Once again photobucket/my computer wont let me post the pics - I'll come back and try again later - caught it unawares I hope - parts for re-furbishment   1275%20parts_zpsjjhgdblo.jpg
Edited by johnR, 20 March 2017 - 01:36 PM.
#180 johnR
johnR
  • 2,325 posts
Posted 02 April 2017 - 04:25 PM
I've taken advantage of the sunshine to wire wheel a few parts of the 1275.  Then I hammered out the convex dimple on the timing cover in case I decide to go Duplex, together with a few other dents and while I was at it ground off the timing set-up thingy that I hope I read correctly isn't any use for anything! Now I'll get these parts blasted to remove the old paint other methods can't reach, then repaint them. Also started sanding and polishing the clutch cover - a bit more work required although I'm not going too crazy with it.1275%20timing%20cover_zpszwwrdmqt.jpg 1275%20rocker%20cover_zpsapi1yost.jpg
covers%20ground_zpsj0mxvqr7.jpgtiming%20cover%20ground_zpsjlvodv4u.jpgpolished%20clutch%20cover_zpskjrarqrn.jp
