'89 Mini City To 'mk1 Cooper S'
617 replies to this topic
#136 psmini
psmini
  • 286 posts
  • Local Club: None
Posted 28 September 2015 - 06:54 AM
Looks amazing!  I plan to do a Euro trip in my SPI Mayfair in the next couple of years.  Glad you like the UE boom, I work for Logitech who make them and they're great.
#137 johnR
johnR
  • 2,297 posts
Posted 18 October 2015 - 05:57 PM
Having completed 2000 miles across Europe without a hitch we went to Devon and in the rain on the way back the alternator failed and I've noticed the water pump is rumbly.
I thought I'd replace the alternator nose bearing first and bought one locally for a tenner.
Then I noticed that Gold Lion Auto-Electrics on Ebay do a complete re-furbish kit including both bearings, brushes, slip rings, rectifier and regulator for £15!!
Once it arrived I started re-fitting it only to forget to replace the slip rings insulator.
This meant I had to destroy the new rings getting them off the rotor again.
I rang Gold lion to order new ones and they sent them for the cost of the postage only.
You don't often get that level of customer service!
I made a new insulator from the side of an orange juice tetra-pak and fitted the new rings.
I polished the casings and re-painted the stator ring so just need to wait for the nuts & bolts to be re-plated to finish it off.
I also bought an NOS Smiths 80mm tacho on Ebay which I've wired up - now waiting for a dash housing for it on back order from Minispares.
It's great to see the tacho needle surging - brings the dash alive010_zpsfmnvwaxj.jpg
Edited by johnR, 01 November 2015 - 09:38 AM.
#138 johnR
johnR
  • 2,297 posts
Posted 18 October 2015 - 06:00 PM
sorry computer refusing to show pictures again!!
#139 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 19 October 2015 - 08:52 AM
Neat Smiths tacho. It'll look good in your car.
#140 johnR
johnR
  • 2,297 posts
Posted 21 October 2015 - 02:55 PM
My tacho pod arrived from MiniSpares together with a new water pump.
I've fitted the pod and wired it in except a feed from the lights for the dial illumination.
I also picked up the newly plated parts for the alternator and re-assembled that - looks very shiney now!
Just need to repaint the pulley and fan and I can get it back on.
tacho%20in%20pod_zpsysgkietq.jpg[/URL]
Edited by johnR, 01 November 2015 - 09:35 AM.
#141 johnR
johnR
  • 2,297 posts
Posted 28 October 2015 - 11:03 PM
I've replaced the waterpump - the bearing was rough after seven years idle even though it wasn't leaking.
I bolted the newly re-furbished alternator back on and started it up to discover that it still wasn't charging!
No obvious reason until it came to me in the middle of the night several days later - I'd taken the knackered speedo and the associated loom off the car while I sorted a new one - the earths that join on the back of the speedo are obviously critical to the alternator working!
with the extension loom plugged back in it all works fine again so there hadn't actually been anything wrong with it to start with Doh! You live and learn - at least the alternator is like new! And I've had the experience of re-furbishing it and found a good parts supplier.
With the stress of it all the battery seems to have died - but I'll triple check that it really is before I replace it!
copying the IMG from photobucket then 'control v' seems a complete fail for photos on my computer now - anyone any suggestions of another way?
John
Edited by johnR, 01 November 2015 - 09:32 AM.
#142 Keith Staley
Keith Staley
  • 83 posts
Posted 29 October 2015 - 06:22 PM
When in photobucket, copy the 'Direct' link > then on TMF - reply to this topic > click on the image icon > paste the link inside the box & click ok > then hit the post button > done
#143 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 October 2015 - 07:28 PM
Or just copy the IMG code, and then in the 'quick reply' box on TMF, right click and then click 'paste'
It will display as a line of jargon until you click 'post' and then the picture is there
#144 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 October 2015 - 07:29 PM
John
control and P is paste
#145 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 29 October 2015 - 08:22 PM
Control and P is print
#146 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 October 2015 - 08:28 PM
Yes, you are quite right..
Been one of those days
#147 johnR
johnR
  • 2,297 posts
Posted 01 November 2015 - 09:49 AM
Hah! I caught my computer off guard this morning and posted all the pictures it hadn't let me through the blog! Result!
JohnR
#148 johnR
johnR
  • 2,297 posts
Posted 07 November 2015 - 04:38 PM
I'd fixed the alloy oil cap by cutting the lip on the rocker cover neck lip down to just enough to engage with the thread on the cap but it leaked oil when it got warm so I've bought a proper threaded ring - and ordered some steel tube to make an internal stepped stub to connect the two.
John
#149 johnR
johnR
  • 2,297 posts
Posted 11 January 2016 - 05:21 PM
The adapter has been turned up and the cap fitted.
I took the car out for a short run between storms recently and nearing home noticed a cloud of white smoke following me!
Stopping outside my garage to open the door left a large puddle of oil on the drive which didn't bode well!  The oil was coming out by the end of the rocker cover so I bought new gaskets and fitted one of them only to find the oil pumping out as before! Further investigation showed a hole in the plastic oil pressure gauge pipe so I've bought and fitted a steel braided one.
Celebrated no more leaks with a run down to the beach for a photo in a rare moment of sunshine and bought some hiLo's ready to lower the back end to a more even keel at some point.
Edited by johnR, 13 January 2016 - 03:42 PM.
#150 mk1leg
mk1leg
  • 9,343 posts
Posted 11 January 2016 - 11:21 PM
wow that's stunning......here is some of my mk1 retro mini.....
