Hif Damper Modifying
16 replies to this topic
#16 Ethel
  • 25,943 posts
Posted 19 May 2015 - 08:56 AM
Pinched this huge piccy from http://www.sw-em.com...m/su_carbs.htm
It's HS but the same principle, note slowing piston rise makes the mixture richer. The effect of the mod will act on the piston  as you lift off the throttle, allowing it to drop quicker and be lower (hence richer) when you floor the throttle once back in gear.
#17 Mini Manannán
Mini Manannán
  • 2,857 posts
  • Local Club: man Estate
Posted 19 May 2015 - 09:58 AM
Reduce the top hat rim to 7mm diameter.
AC
Pinched this huge piccy from http://www.sw-em.com/su_carbs.htm
It's HS but the same principle, note slowing piston rise makes the mixture richer. The effect of the mod will act on the piston  as you lift off the the throttle, allowing it to drop quicker and be lower (hence richer) when you floor the throttle once back in gear.
So is that the rod, the ring or the cylinder?  (the rod end looks most top-hat-ish to me :-/ )  Also, is this a further improvement over the 'fast drop' damper or an improvement to the standard?
Edited by Mini Manannán, 19 May 2015 - 09:59 AM.
