Hif Damper Modifying
16 replies to this topic
#1 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 06 April 2015 - 11:56 AM
Dear all,
Can anyone provide me with information on modding the HIF 44 damper to the fast drop type. I know I've seen information on it before I'm just not sure where.
Regards
A
#2 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 06 April 2015 - 07:10 PM
Search "hif44 damper" in the technical forum. You'll find items like http://www.theminifo...4/?fromsearch=1 and more.
#3 liirge
liirge
  • 4,097 posts
Posted 06 April 2015 - 07:18 PM
That's not actually what I inquired about at all, but thank you for trying.
I remember seeing somewhere that you could modify the damper of the slow fall to act like a fast fall damper. I was hoping that someone remembers this like I do, and can either detail what is done, or the relevant material online.
#4 carbon
carbon
  • 2,590 posts
Posted 10 April 2015 - 06:40 PM
AC Dodd is the best person to answer this one.
To make the SU damper offer less resistance when dropping the height of the floating brass cylinder at the end of the damper needs to be reduced (from memory by about 1mm).
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,737 posts
Posted 10 April 2015 - 09:50 PM
No, do not shorten the sleeve. Reduce the diameter of the top hat rim.
AC
#6 carbon
carbon
  • 2,590 posts
Posted 11 April 2015 - 10:19 AM
I stand corrected, go with AC Dodds recommendation!
#7 whistler
whistler
  • 1,788 posts
Posted 16 May 2015 - 06:54 PM
AC
By how much should you reduce the diameter of the top hat rim please?
#8 racingbob
racingbob
  • 3,061 posts
Posted 16 May 2015 - 06:57 PM
what difference is there in the fast drop
and why do you need it done
#9 whistler
whistler
  • 1,788 posts
Posted 17 May 2015 - 11:21 AM
Whilst I am fully capable of stripping and rebuilding an SU I am an amateur when it comes to the complexities of the accurate workings of it. I have a HIF44 with a LZX1511 damper fitted. This, apparently, is the wrong damper for this carb; it should be LZX2085. After reading various forums I have come to the conclusion that the LZX2085 lifts and falls quicker than the LZX1511 due to the smaller diameter of the top of the plunger assembly. I have a problem with hesitancy when touching the throttle which could be because the piston is not lifting quick enough to allow an increase in fuel through  the jet assembly. A reduction in the diameter of the plunger 'top hat' makes sense to me and rather than pay £12 or more for a new LZX2085 I can reduce the diameter myself so I was merely asking by how much should I reduce the diameter. Hope that makes sense.
I am using 3 in 1 oil in the dashpot.
#10 racingbob
racingbob
  • 3,061 posts
Posted 17 May 2015 - 11:58 AM
I use 3.1 and got the 2085 seems ok
wasn't as good till I put the 2085 on
#11 whistler
whistler
  • 1,788 posts
Posted 17 May 2015 - 04:13 PM
I'm just trying to do the same by modding the 1511 and saving £12! Lol
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,737 posts
Posted 18 May 2015 - 05:04 PM
Reduce the top hat rim to 7mm diameter.
AC
#13 blacktulip
blacktulip
  • 6,224 posts
Posted 18 May 2015 - 05:19 PM
Is this an actual benefit or is this a tuning aid?
#14 ACDodd
ACDodd
  • Mini Docs
  • 2,737 posts
Posted 18 May 2015 - 05:21 PM
It simply removes flat spots between gear changes.
Ac
Edited by ACDodd, 18 May 2015 - 05:22 PM.
#15 whistler
whistler
  • 1,788 posts
Posted 19 May 2015 - 08:05 AM
AC
Thanks, that's the info I needed.
