Oil Pressure Too High?
Best Answer Cooperman , 05 April 2015 - 08:59 PM
Cold at initial start up should be up to around 90 psi with fresh oil and choke on.
Once warm the pressure will depend on the revs, as always, but as a guide a good engine will give around 60 to 70 psi at over 4000 rpm, 50+ at 3000 rpm and 20 to 25 psi at tick-over of around 1000 rpm.
Those are just general figures and a bit either way is not a problem.
Go to the full post
8 replies to this topic
#1 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 05 April 2015 - 03:19 PM
Hi guys,
Had the oil pressure gauge reading over 100 psi yesterday when checking for oil pressure and I've been advised it's too high.
Attached File  image.jpg   71.7K   6 downloads
Should I be worried? I'm using 20/50 Comma Sonic and the oil was cold as I the engine wasn't running, I was just checking for oil pressure. I'm just concerned that if it's like that at cranking speed, what's it going to be like at 1500 - 2000 rpm for the initial run in?
What do you suggest? Adjustable valve? (Which I might have a go at making).
I've got a brand new spring and ball in at the moment.
Also what pressure should I be looking at ideally?
Thanks,
Ian
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 05 April 2015 - 03:29 PM
When using the ball bearing and spring instead of the standard plunger you need to trim the spring to get the oil pressure down.
I cannot remember the actual procedure that is detailed on here but I believe trimming a half coil at a time till the oil pressure at idle and cold is around 60psi, but double check before doing anything!
#3 coopdog
coopdog
  • 4,506 posts
Looks like you need to trim the spring a bit to lower it
Mines at 45psi at idle
Mines a turboed engine but should make any difference
I know people who have as low as 25 psi and as high as 100psi
But your just gonna increase wear at those pressures
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 05 April 2015 - 04:10 PM
My engine (1993 built, 1275, NA with stage one kit) is 60 psi running under load(hot or cold)
40 psi at idle(hot)
#5 Cooperman
  • 23,278 posts
Posted 05 April 2015 - 04:26 PM
Fit a plunger type relief valve & spring. The ball type has been known to cause all sorts of pressure issues including too high at cold and fluctuating at medium revs.
#6 Spider
  • 14,849 posts
Posted 05 April 2015 - 06:21 PM
I was just about to say the same thing.
#7 A-Cell
A-Cell
  • 1,610 posts
Posted 05 April 2015 - 06:53 PM
+1, fit standard thimble one
#8 59 Speed
59 Speed
  • 674 posts
Posted 05 April 2015 - 08:56 PM
Cheers guys!
I'll swap it back to the plunger / thimble one I took out.
I might have a go at making an adjustable regulator out of the existing gallery plug.
What should the ideal pressure be though with cold and warm oil?
Cheers again,
Ian
#9 Cooperman
  • 23,278 posts
Posted 05 April 2015 - 08:59 PM   Best Answer
