A Car Jack For Mini?
26 replies to this topic
#16 TheOriginalSkunk
TheOriginalSkunk
  • 125 posts
Posted 04 April 2015 - 03:26 PM
ill mesure and check first then anf if not grab a scissor jack
#17 fenghuang
fenghuang
  • 796 posts
Posted 04 April 2015 - 03:49 PM
(As I recommended them, I should add I don't actually have a bottle jack in my Mini!)
#18 mister bridger
mister bridger
  • 911 posts
Posted 04 April 2015 - 03:53 PM
Bear in mind that if you're changing a puncture at the side of the road the clearance is going to be even less than usual
#19 Georgea2405
Georgea2405
  • 58 posts
Posted 17 July 2015 - 10:39 PM
Hi,
I am looking at a bottle Jack a 2 tonne. Will this fit under my mini?
It's a B&Q 2 tonne bottle Jack
#20 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 17 July 2015 - 10:50 PM
Hi,
In my opinion, no. I would buy a small, and light, trolley jack. :shades:
#21 Georgea2405
Georgea2405
  • 58 posts
Posted 17 July 2015 - 10:59 PM
It is 18cm tall?
#22 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 17 July 2015 - 11:18 PM
It is 18cm tall?
Well, all you can do is try it, but in my head I can't see a bottle jacking fitting underneath a mini subframe, with a flat tyre. :unsure:  :tumble:
#23 Broomer
Broomer
  • 1,771 posts
Posted 17 July 2015 - 11:37 PM
It is 18cm tall?
Way to tall for any mini that has been near a lowering stick.
#24 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 18 July 2015 - 04:04 PM
As above, a bottle jack will be way too tall, especially if you're using it to change a flat tyre which will make the car even lower than normal.
As I mentioned previously, a scissor jack is more practical for emergency roadside use, not only do they have sufficient clearance to get under the subframes, a small one will also fit quite niceley in your boot when stored on it's side between your spare tyre and the boot hinge panel.
#25 Ethel
  • 25,920 posts
Posted 18 July 2015 - 05:12 PM
The jack isn't as important as where you put it. The jacking point on the sill is only suitable for the original, supplied, jack. Then, you can only be sure of the underlying structure if you know it's been repaired along with any inevitable sill replacement. Any other jack is best placed under the subframe where the suspension arm attaches.
#26 pusb
pusb
  • 1,216 posts
Posted 19 July 2015 - 07:28 AM
It seems previous owners of mine didn't know the correct place to jack up a mini. My passenger footwell looks like the surface of the moon!
I would never use the standard point in the sill either. When my wheel fell off I had to, as the subframe was to close to the ground to get the jack under it. Using the standard jacking point just that once cracked my inner sill. And my car seems solid and fairly rust free.
#27 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 19 July 2015 - 10:52 PM
I have a plastic tub in the boot of my car with a trolley jack and a couple of planks of wood. If I get a flat on the front tyres it's too low to get the jack under unless I drive onto the wood first.. Need some new cones!
