My son has rebuilt a 1975 Mini Clubman. He has fitted Metro 4 pot calipers with a bias valve fitted on the rear sub-frame. Otherwise the standard single brake line configuration has been retained. The only other modification has been to install a remote brake servo. This servo was completely overhauled using a genuine service kit. Everything appears to work perfectly except when slowing down. When slowing down to a stop, the servo is applying the brakes without the brake pedal being depressed. The brakes release again only when the accelerator pedal is pressed. The servo does not lock the brakes, but merely causes them to bind enough to prevent any free-wheeling.
All of the hoses are new and as I say all of the parts were replaced using a genuine service kit. I've checked that the non-return valve in the vacuum hose connecting the manifold to the servo is the correct way round. The only part which is not correct, is the adaptor to connect the vacuum hose from the manifold to the servo. We managed to obtain a similar part from an engineer. We could not locate the correct item.
Can anybody help please?
