I own a '68 Mini Traveller with an SU fuel pump mounted on the rear subframe. The current pump may be original to the car, and it had intermittent problems which left me stranded twice last fall. It didn't seem worth re-building the old pump when I compared the cost of the parts to that of a new pump.
I bought a new SU pump (part number is AUF214) which is a replacement for the original:
The new pump has two vent pipes on the front and rear of the black body. What type of tubing should I use for vent hose, and where should a route the hoses in a Traveller? The installation instructions state "the vents should be piped to a region of dry air e.g. car interior or luggade compartment."
It is logical to run vent hoses to the spare tire compartment, but I can't find any existing openings. The old pump did not have vent hoses attached.
Thanks in advance,
David Schwartz
