My VHPD Rear Engined Rear Wheel Drive mini
#31
Posted 27 July 2006 - 07:32 AM
#32
Posted 27 July 2006 - 12:16 PM
What silver paint did you use to paint the gearbox, so I can get some to paint mine, it looks quality!
Kool car, if your living in leam next year u must be a warwick uni student like me right??
Mark
#33
Posted 27 July 2006 - 01:47 PM
#34
Posted 27 July 2006 - 03:29 PM
or was you restricted by length of gear control cables ??
Edited by v8mini, 27 July 2006 - 03:30 PM.
#35
Posted 29 July 2006 - 12:25 AM
I have read youre build diry about 3 times. That mini is amazing, it will be so cool when it finished.
Well done for producing such an amazing mini.
Keep up the good work Andy.
Chris.
#36
Posted 04 August 2006 - 10:53 PM
Sorry, the group2's got binned during a shed clearing when i moved house - chucked away a load of stuff i shouldn't have, but had nowhere to keep it all in the new house
#37
Posted 09 August 2006 - 01:09 PM
#38
Posted 10 August 2006 - 08:35 AM
does the mgf gear linkage cables allow it to be mounted nearer than you have? ie where the standard mini gearstick is?
Yeah, theres a fair bit of slack in the cables, so the assembly can be moved forward to way past the original gear lever mounting place if you wanted.
#39
Posted 22 August 2006 - 06:23 PM
been playing with the exhaust today. for those of you who dont know im using a Series 1 elise backbox which looks like this
thats not mine by the way, mines a new one. My silencer is also bigger because its a standard item, whereas that one is a janspeed performance one. Mine will be loud enough tho
Im mounting it upside down so the inlet is on the correct side, this also means the tailpipes come out the valance instead of the boot. Ive also offset the silencer to the NS, to allow more room for the inlet elbow
So here it is fitted - just need to make the inlet elbow, and make a joint between the manifold and silencer. Im quite chuffed because none of of it sticks out under the valance too far so its quite subtle, and all the piping cant be seen unless ur kneeling under the car.
and heres the view from above, its a tight fit, but with a bit of tweaking it will fit very nicely in the space.
Sorry about the pics - it was pretty dark in the garage
heres a mock-up of how it weould look that i did ages ago - its a better photo so you get the idea of whats going one
#40
Posted 23 August 2006 - 10:02 AM
#41
Posted 23 August 2006 - 01:33 PM
#42
Posted 25 August 2006 - 11:34 AM
i am thinking that my resto is just yearning to have this done to it seeing as it is stripped out already and is now a perfectly sound shell. I am hesitant about cutting the arse off but really want a 16v mini. would you reccommend this as a good project for someone with good tech knowledge and welding skill but limited 16v knowledge. It seems as though the more technical bits are structural rather than engine , is this the case??
Ted
p.s. Mucho Impressto senioro
#43
Posted 25 August 2006 - 02:30 PM
#44
Posted 25 August 2006 - 08:58 PM
Cheers mate
#45
Posted 08 September 2006 - 10:33 AM
