Correct Fitting Of Group 2 Arches?
8 replies to this topic
#1 Haynes
Haynes
  • 489 posts
Posted 22 March 2015 - 10:15 PM
I recently fitted some group 2s and had to go higher than Id like to cover up the holes left by my previous arches.  I'm now thinking I need to weld up the old holes and then a bit of paintwork so that I can get them right.
One of the consequences is that it looks a little untidy as theres a gap between the arch and the original bodywork lip.  Also the front age is a couple of cm above the front bumper, looking at most grp 2 fits the front sits lower.
Should grp 2s sit pretty much on the lip of the bodywork?  Are they any guides online?
#2 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 22 March 2015 - 10:57 PM
I brought some group 2's from Mini Spares, the ones which bolt into the original Mini Special arch holes. This is the best photo I've got, but at the front, they sit about 10mm from the top of the bumper.
What do you mean by "lip of the bodywork"? The vertical seam? Or the arch lip?
B7D5AD89-C910-4A75-88B0-40107A614116_zps
#3 Haynes
Haynes
  • 489 posts
Posted 23 March 2015 - 01:12 PM
Sorry, I did mean the wheel arch lip.  Should the Grp 2s be sat on that?
#4 Will16
Will16
  • 1,090 posts
Posted 23 March 2015 - 05:28 PM
Mine are about 1/2" to 3/4" above the arch lip :)
#5 Cooperman
  • 23,278 posts
Posted 23 March 2015 - 11:21 PM
With the Group 2 arch extensions, the lip of the arch extension should be the same height above the horizontal body datum as the original arches. So when looked at from the side the lips of the original arches and the arch extensions will be in the same relative positions to the ground.
#6 Haynes
Haynes
  • 489 posts
Posted 24 March 2015 - 01:21 PM
That is pretty much how they are and makes me feel better about how i have them.  I think mine sit a little high above the bumper at the front because the wing had been modified to accommodate larger wheels.
#7 Haynes
Haynes
  • 489 posts
Posted 25 March 2015 - 01:41 PM
Looking at pics of grp 2 arches Ive now realised there are at least a couple of different types.
Mine are the Mini sport ones, like WILL16s, which tuck round the rear valance but the front one stops on or above the front bumper.
However the Mini Spares ones appear to stop at the rear seam then the front one wraps around the front valance.
Has anyone got pics of the Mini Spares Centre grp 2s they can post?
#8 johnR
johnR
  • 2,297 posts
Posted 07 June 2015 - 09:12 PM
I'm going to fit MiniSport Group 2 arches - do people recommend a beading between the arch and the body - if so what have you used?
JohnR
#9 Cooperman
  • 23,278 posts
Posted 09 June 2015 - 07:24 PM
JohnR
It's up to you really. The original Group 2 arch extensions were fitted to FIA Group 2 competition Minis with no beading, but these days you can add a beading if you wish. I'm sure you can easily find some on-line.
