Ecu Types
9 replies to this topic
#1 simplyminis
simplyminis
  • 2,164 posts
  • Local Club: m4minis
Posted 20 March 2015 - 07:42 PM
I have a ecu off a 94 cooper 101040
whats the difference ive seen other like a 101170 etc
thanks
E834BED5-C202-44D6-9D89-EFD42CA9E175_zps
#2 jayh29
jayh29
  • 219 posts
  • Local Club: Box Hill mini group
Posted 20 March 2015 - 07:53 PM
Hi mate,
I think the cooper ecu's had better fueling, and any ecu with 11 needs a code from the alarm box before it will work.
Hope this helps.
cheers
Jay.
#3 simplyminis
simplyminis
  • 2,164 posts
Posted 20 March 2015 - 08:03 PM
cheers im going to put it on ebay but wanted a better idea what type is was thanks
#4 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 20 March 2015 - 08:09 PM
pretty sure the 101040 isn't a cooper ecu and the 101170 is a cooper ecu
you need an engine to go with the cooper ecu to get any benefits though, its not a bolt on sort of upgrade to the standard ecu as far a I know
#5 simplyminis
simplyminis
  • 2,164 posts
Posted 20 March 2015 - 08:11 PM
it came off a cooper and was running
#6 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 20 March 2015 - 08:23 PM
might have been swapped prior to you getting it maybe
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 20 March 2015 - 09:50 PM
Per Somerford Mini: The MNE101070 is the Cooper manual with no codes. The MNE101040 is for a manual Sprite or Mayfair with no codes.
http://www.somerford...page=page&id=76
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 21 March 2015 - 12:18 AM
It's a standard non cooper ECU without immobiliser coding as noted above.
Cooper ECU has different tables in the ECU coding with different fuelling, cooper engine has higher compression ratio (Pistons) than standard and AFAIR a different camshaft profile.
FS
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 March 2015 - 08:40 AM
The cooper has a different camshaft, and also the shorter 3.2 final drive, other than that mechanically they are identical.
#10 spiguy
spiguy
  • 1,537 posts
Posted 21 March 2015 - 08:52 AM
pretty sure there are two different CR options on the 1275 Spi. From minimania:
1275cc, 1990 onwards (12A numbers)
12A/2A            Carburrettor type
12A/2B            Carburrettor and catalyst type
12A/2D            SPi (Single Point injection - Tbi, throttle body injection) with 9.4-1 CR
12A/E              SPi (Tbi - throttle body injection) with 10-1 CR
With the following suffixes:
F53                  10.0-1CR, 3.105 final drive, catalyst, oil cooler
F75                   9.4-1CR, SPi, 3.105 final drive, closed loop catalyst
F76                   9.4-1CR, automatic with closed loop catalyst
F77                  10.0-1CR, SPi Cooper, 3.2 final drive, closed loop catalyst
G01                  10.0-1CR, 3.105 final drive, catalyst, no oil cooler
G03                  9.4-1CR, 3.105 final drive, catalyst, May 1992 onwards
G04                  9.4CR, 2.76 final drive, catalyst, French only spec
G05                  9.4-1CR, automatic with catalyst
Edited by carlukemini, 21 March 2015 - 09:24 AM.
