Wiper Motor Repair
17 replies to this topic
#1 Wholord
Wholord
    Just On Tickover
  • 9 posts
Posted 20 March 2015 - 10:37 AM
Hi guys
I have disconnected the wiper motor and the rack is connected to the wiper motor. A few questions regarding how to disconnect the rack as I don't think I need to buy that part. also where is the gear in the wiper motor. if I buy a new motor the gear I need to purchase separately so where would I need to connect it to. I haven't done this repair before so a little unsure as to how to do it all. a few tips and steps to follow from you guys would be much appreciated. Its a 1990 rover mini and when they worked the options were on 1 speed, or hold down and they would go 1 wipe. thanks. any pics of how to do this replacement would be great.
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 March 2015 - 10:48 AM
You are right, new motors do not come with the gear but you can most likely fit your existing gear if the condition of it is good and assuming it's that the motor that's stopped working.
To disconnect the rack, you will need to unscrew the 4 small bolts holding the face plate onto the front of the motor and then you will see a 'C' clip holding the rack arm onto the workings. Slide the clip off and the rack will disengage from the gear and you can pull the motor out. The rack will simply by slipped onto a post on the rack arm and should just pull off
Ben
Edited by Ben_O, 20 March 2015 - 10:50 AM.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 March 2015 - 10:52 AM
#4 Wholord
Wholord
    Just On Tickover
  • 9 posts
Posted 20 March 2015 - 11:00 AM
excellent thanks explains a lot
#5 Wholord
Wholord
    Just On Tickover
  • 9 posts
Posted 20 March 2015 - 02:05 PM
http://www.minisport...-1967-2001.html
part all ordered will get the gear out later. I'm hoping its the motor and not just any of the connections however I cleaned them up and it still didn't work so I assume the motor
#6 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 20 March 2015 - 02:17 PM
Practical classics is doing a two-parter on wiper motors .. part 1 this month: taking it apart ...
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 March 2015 - 02:55 PM
Did you check the brushes?
also sometimes the park switch/wiring connector corrodes inside causing malfunction
#8 Wholord
Wholord
    Just On Tickover
  • 9 posts
Posted 21 March 2015 - 06:18 PM
I cleaned all the electrics and brushes and it still didn't work. I am waiting for the motor and removing the gear now but not sure how to disconnect the gear
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 March 2015 - 06:23 PM
On the back of the motor housing, the shaft for the large cog goes though a hole. There will be a 'c' clip on there. Remove that the the big cog will slide out of the housing.
Here is a picture of all of the component parts so you know what you are dealing with.
This is a 1978 motor but will be largely the same component wise. It's just the motor barrel thats different.
Ben
#10 Wholord
Wholord
    Just On Tickover
  • 9 posts
Posted 22 March 2015 - 09:19 AM
Thanks I located the c clip and took it off last night there buggers to get off. Thanks for that pic though. I guess with the new gear everything goes back as it came off
#11 Covert
Covert
  • 526 posts
Posted 22 March 2015 - 09:48 AM
Just finished restoring my 1975 motor, just remember cleanliness is key, and lots of good qulity grease
#12 90BHP
90BHP
  • 192 posts
  • Local Club: Back Street Minis
Posted 22 March 2015 - 01:12 PM
Just finished restoring my 1975 motor, just remember cleanliness is key, and lots of good qulity greaseimage.jpg1_zps5lare8lh.jpg
Looks fantastic, how did you get the original finish ?
#13 Covert
Covert
  • 526 posts
Posted 22 March 2015 - 07:25 PM
This was it before , i stripped it down sand blasted the body to get rid of paint and dirt, started with vinegar to get rid of most of the rust and then various other chemicals , then replated it , fitted new wheel boxes etc , im happy with it , pic is crap lol
c38fa35e-4633-4546-8125-79143c60222d_zps
#14 90BHP
90BHP
  • 192 posts
Posted 22 March 2015 - 10:12 PM
Any details on the plating ?
#15 Covert
Covert
  • 526 posts
Posted 23 March 2015 - 07:05 AM
http://gaterosplatin...Plating-kit.php
this is this kit i bought , very easy to do but the prep work is time consuming , its paid for itself 4-5 times over though as ive plated so much stuff
