First Engine Build - 1293!
3 replies to this topic
#1 Mini Cheddars
Mini Cheddars
  • 1,209 posts
Posted 14 March 2015 - 03:06 PM
Hi all!
So I'm planning my first engine build, which will go into my only car so will be a daily driver. I travel about 20 miles up the motorway every day for work. Preliminary plans are:
Re-bore to 1293
Either 21253 from Minispares or Omega forged pistons from MED
1.3 rockers, possibly from MED
Kent 276 camshaft
Kent Cams duplex timing gear
Megajolt MAPS ignition
Re-ground and balanced crankshaft
Possibly a bit of flywheel lightening
Gearbox check-over and recondition by Guessworks (yet to contact him though)
Head? Pretty much undecided so far. May go MED, may go Minispares, may go Mini Sport, or may go elsewhere!
Will probably stick to 3.4 FD
I'm told it already has a central oil pick-up pipe, but I can't see the pipe that goes under the big gear
I'm probably forgetting something!
PICS!!!
11034450_10205974981714426_6619849281266
11038083_10205974982034434_8471370989261
11041877_10205974982074435_3372452013885
11043327_10205974983314466_7312926730556
10860911_10205974983994483_3851799125455
11052404_10205974984554497_1125880754672
10854408_10205974984674500_4022000477521
10649592_10205974984994508_3855374960856
10750192_10205974985394518_8344974812148
11044586_10205974985874530_5889247152525
11000711_10205974986074535_3277967440779
11050777_10205974986634549_6098329439612
11050784_10205974986754552_3395230414149
11018821_10205974987394568_8476354344986
10857352_10205974987834579_9090447654632
Edited by Mini Cheddars, 14 March 2015 - 03:15 PM.
#2 Bubblebobble
Bubblebobble
  • 661 posts
Posted 14 March 2015 - 04:23 PM
I would not bother buying forged pistons if its  a fast road build , unless you plan to be revving the guts out of it.
#3 Mini Cheddars
Mini Cheddars
  • 1,209 posts
Posted 14 March 2015 - 06:44 PM
Maybe not revving it all the time, but for convoys to shows there may be times when I do.
Like I say, it's just a preliminary build plan at the moment. Subject to change!
For anyone interested, I'm selling a reconditioned 12G295 head in the For Sale section that I was going to put onto my daily, but that plan changed.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 14 March 2015 - 08:05 PM
good luck......
