engine number 12h996aa 138659If there is an engine number available (12H) put it up on here and it should be able to work out year etc.
MG Metro 1300 leaded fuel pre 1989 1275cc 12H996AA - So if the head is original it'll have the 35.6mm inlet valves and higher CR. If you want to run unleaded juice you may need hardened exhaust seats. Or go for a petrol additive if you don't do much mileage.
cheers ,would it be fine with the additive or is it better just to do the seats ?
Edited by paulusmaximus, 14 March 2015 - 10:10 PM.
