hi ..ive recently bought an mg metro engine for my mini ,it has no carb and i was wondering which carb would be best for performance and reliability . i would also appreciate any tips on squeezing a few extra horse power out of it . thanks
Mg Metro Engine Tuning
Posted 13 March 2015 - 09:12 PM
Posted 13 March 2015 - 09:15 PM
Hi..you need a HIF44 carb but this will not tune your engine alone...........a stage 1 kit would involve a bigger valve head and exhaust...then you could think of a new camshaft...it depends on how much money you want to spend....
Posted 13 March 2015 - 09:16 PM
An HIF44 on a good alloy inlet manifold.
With regard to other improvements, what is the car to be used for and how much can you afford to spend?
Posted 13 March 2015 - 09:28 PM
Not sure of budget at the minute ..It would just be used as fast road but wanted to see what my options were whilst the engine was out of the car . what would a full stage 1 involve and what sort of power increase would it achieve ? i was told these engines already had a good cam or would it be worth changing ? thanks
Posted 13 March 2015 - 09:46 PM
When they left the factory they had circa 72hp, however, as the last one was built over 25 years ago, I would not be surprised if that had dropped considerably.
As for getting more horses out of it... until it gets a full rebuild, I'd suggest a good service
Posted 13 March 2015 - 10:04 PM
It's a classic Mini, so you must mean 'not quite so slow road' .
Fast it's never going to be.
Posted 13 March 2015 - 10:08 PM
The engine hasnt ran for a while but turns by hand .its definitely getting a rebuild but wondered if it was worth upgrading anything along the way . if i got a hif44 carb and upgraded the exhaust and air filter ,would the next step be a bigger valve head ? if so which head would best suite this engine . sorry about all the questions ha ha i just want it to be right first time as the whole car is being restored from the ground up ..cheers
Posted 13 March 2015 - 10:14 PM
ha ha your right there!
Posted 13 March 2015 - 10:40 PM
As its the MG Metro spec engine a stage 1 kit is not really designed for that engine, stage one kits are for standrd cars, rebuilt with the current head overhauled and a kent 266 cam a HIF 44 SU with a LCB into a good system, is going to make a quick'ish (by Classic Mini Stds) little Mini, and most of all one with good torque for all road work. This would also make a good Sunday blast in the country engine.
Posted 13 March 2015 - 10:54 PM
thanks thats really helpfull . sounds like a plan
Posted 13 March 2015 - 10:56 PM
The MG Metro engine already has a "Big valve head" (35.6mm) as standard, High CR (10:4 to 1) and the cam if in good condition is ideal. Make sure the engine is healthy (bore wear etc), rebore to +20 if required, then as people have suggested put an HIF44 on (An original MG Metro) alloy inlet manifold. A decent LCB (Stg 2 Maniflow) + RC40 exhaust, and a set of 1.5 ratio rockers and your little mini will be more than a match for modern traffic. 80 brake isn't unrealistic if set up properly on a RR.
Don't start changing cams etc unless it is damaged or worn out.
Posted 13 March 2015 - 11:13 PM
ok cheers so the engine just needs a strip down and if the existing internals are all good then it sounds like a pretty good set up anyway without any upgrades ? thats better than i expected.
Posted 13 March 2015 - 11:27 PM
Just before we all get too excited, what capacity Metro Engine is it? They had 850's, 998, and 1275's.
Posted 13 March 2015 - 11:28 PM
Since your going to rebuild it go the extra mile and get an SW8 cam and a good large valve head....Med do some fantastic heads for under 1k Sw8 kit £!50....a good Duplex timing gear kit £150.....
Posted 13 March 2015 - 11:30 PM
