Correct Grease For Wheel Bearings
6 replies to this topic
#1 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 12 March 2015 - 02:45 PM
Afternoon all,
Can somebody clear this up for me; what grease is needed for wheel bearings? Castrol Multipurpose (Castrol LM replacement) or Castrol High Temperature? Both products say that they are suitable for wheel bearings but the more I read around the more confused I get. Some say Castrol LM is fine, others a High Temperature grease.
Cheers,
Dave.
#2 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 12 March 2015 - 02:57 PM
http://www.timken.co...eelBearing.aspx
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
I hate to add to your confusion... but either should be fine.  That said, I tend to use high-temperature grease just to make me feel more comfortable.  The one bit of advice I will offer is that if you are re-packing wheel bearings, clean the old hub and bearings up to completely remove the old grease.  Avoid mixing new and old and different types of grease.
#4 dsgoody
dsgoody
  • 519 posts
Posted 12 March 2015 - 04:10 PM
Cheers Doug. I will stick with standard Castrol Multipurpose grease then since I have a tub full of it. The bearings were new so no need to clean out any old grease. Unfortunately they have sat on the shelf for a few years and the packets of supplied grease were robbed a while ago.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 12 March 2015 - 06:09 PM
Wear Nitrile gloves when you repack the bearings, do not use bare hands. The oils / sweat in your skin can cause corrosion to set in.
#6 dsgoody
dsgoody
  • 519 posts
Posted 12 March 2015 - 06:26 PM
Cheers for the heads up. I always wear gloves when dealing with fresh Grease, can't stand the feel of it :(
#7 Spider
  • 14,838 posts
Posted 12 March 2015 - 07:22 PM
I've used both and yes, either are OK on the wheel bearings for a Mini.
