A Lesson In Making Sure Bolts Are Tightened
13 replies to this topic
#1 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 11 March 2015 - 11:34 PM
Last night I had to remove my cylinder head:
Want to see why? Well here's what happened...
Yesterday I fired up my mini to find it was only running on three cylinders... after spending ages checking all the wiring, coil, sparkplugs, distributor, carb etc, I did a compression test and found that cylinder number 3 had no compression whatsoever.. Oh dear.
Got the cylinder head off last night only to find this remarkable sight. The inlet valve, jammed open by the bolt which holds the air filter on! Somehow it managed to find its way through the carb, the inlet manifold and then into the cylinder head.
Safe to say that I was incredibly lucky it didn't make it into the cylinder and cause damage to the piston, nor did it cause damage to the valve or valve seat. I'll consider this a valuable lesson in making sure the air filter bolt is properly tight!
#2 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 11 March 2015 - 11:51 PM
Properly lucky!!!!  Yup, always pays to take your time on the last few bits :-)
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 March 2015 - 11:54 PM
wow, that was lucky!
#4 lsto
lsto
  • 724 posts
Posted 12 March 2015 - 05:28 AM
When I was an apprentice I was working on an old fiesta with another mechanic. I can't remember exactly what he was doing but we had the air filter off and the carb was open with the engine running. Anyway long story short as the mechanic reached over to do something, because the bonnet opened the wrong way we had a load of tools and nuts and bolts on the scuttle panel, he knocked a nut off and it bounced off the engine and straight into the carb.
It went tink, tink tink, down the carb and inlet, then we heard a metallic ring for a few seconds as I guess it rattled round the cylinder and finally a twang ting ting as it came back out the exhaust.
I remember looking at the mechanic in amazement, he looked at me, laughed as if it was normal and carried on doing what he was doing lol.
The whole time the engine never missed a beat. I left that garage soon after...
#5 jaydee
jaydee
  • 8,565 posts
Posted 12 March 2015 - 09:55 AM
The entire bolt sucked all the way to the inlet valve..thats mental
#6 CK's mini
CK's mini
  • Just Joined
  • 113 posts
Posted 12 March 2015 - 10:07 AM
I had a similar thing last year, luckily it never got past the carb. Very lucky. Loctited them on now lol.
#7 robminibcy
robminibcy
  • 1,516 posts
Posted 12 March 2015 - 05:57 PM
I had similar with the grub screw that blanks off the servo take off! Luckily it was to big to get as far as the valves!
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 March 2015 - 08:59 PM
Check it hasn't bent the carb needle on its way through.
#9 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 12 March 2015 - 10:09 PM
I had this thing happen to me...stuck in the inlet of number 1.
Somehow did no damage to anything!
Mine the bolt had broken off the inside of the pancake filter. Cheap parts I suspect.
#10 MiniCarJack
MiniCarJack
  • Just Joined
  • 486 posts
Posted 13 March 2015 - 02:49 AM
The design of the bolt on my filter (or rather technically a stud) is bloody stupid to begin with, the threaded ends are very short and the little nut which retains the air filter has barely any thread to tighten on to. So it easily worked its way loose and before long, got sucked in from inside my air filter and probably spent a month or so inside the carb before finally getting through into the cylinder head!
#11 mk1leg
mk1leg
  • 9,343 posts
Posted 13 March 2015 - 03:16 PM
Well it could of been a lot worse.....all you have to do is remove the valve anf free bolt and check for damage but from pics looks fine
you were lucky........... :highfive:
#12 MiniCarJack
MiniCarJack
  • Just Joined
  • 486 posts
Posted 14 March 2015 - 04:56 AM
I was very lucky indeed, having removed the bolt and checked out the head for any damage, it would appear I got away with only having to spend $50 on a new head gasket set rather than an expensive engine rebuild! Finished putting the car back together again yesterday and it's running sweetly now :)
#13 mk1leg
mk1leg
  • 9,343 posts
Posted 14 March 2015 - 05:47 PM
good job done ...... :highfive:
#14 Chris1992
Chris1992
  • 2,022 posts
Posted 15 March 2015 - 02:54 AM
well now im paranoid about mine! itll be the first thing i check when im next out in the garage  :lol:
