Stiff Clutch Pedal
5 replies to this topic
#1 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 11 March 2015 - 12:23 PM
First time I've used mini since December and notice the clutch pedal action does not seem as smooth as it was. Does it mean slave cylinder is knackered? When clutch is pressed in it works fine, and returns to usual position. It just does not seem to operate as one smooth movement, more like a few small ones.
Maybe just because I've not driven it in a while, and been driving automatic regular car.
#2 blackjack1986
blackjack1986
  • 107 posts
Posted 11 March 2015 - 12:26 PM
Hi had this problem very recently, could be just down to slave cylinder arm being stiff. Spray some wd40 onto the arm/plunger that goes into the slave clyinder and then pump the clutch pedal. Hope this helps.
#3 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 11 March 2015 - 01:51 PM
Will give that a try, cheers! Always miss the simple things!
#4 psychobob
psychobob
  • 205 posts
Posted 11 March 2015 - 02:40 PM
i agree. mine was the same after 6 months off the road. it had set solid at first!
#5 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 11 March 2015 - 02:46 PM
Lubrication!
#6 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 11 March 2015 - 02:47 PM
Lubrication first!
