Posted 12 July 2004 - 12:41 PM
Sorry, hadn't twigged your location.
Best thing to do is probably add a complete new ignition system, to include the tacho. This would leave your original ballasted system in place and un touched to return to if there was ever a problem. Take a feed from terminal 1 in the fuse box, this should be white and the unfused side of the ignition fed wire. Run this through to the tacho and back to the front of the engine bay, run it along the original loom and ty-rap it to same. Replace the coil with a 12volt one, I don't think the points or condenser need changing unless someone knows different. Keep your old coil to go back to if there are any problems, as the 12volt one won't work with the ballast resistor. The other two terminals can be connected to the instrument supply as usual. If the car is pre-disposed to a tacho, then thats great, use the wires you have. Leave the white/black ignition sense wire taped in the loom though, and make sure its terminal is nicely insulated. The wire from Terminal 1 is how I have fitted Magnetronic kits in the past, and works well.
That is if you have ballasted ignition, if not you can just cut the tacho into the coil feed wire from the ignition switch as if you were cutting in an immobiliser. Make it easy to bypass the tacho in case it fails, maybe with a good quality switch. Make sure any connections for the ignition are good and sound though, as intermittant signals can be a real pain to fault find in the ignition. If you're not sure about doing this, or about the condition of your tacho, get an auto electrician to do it.
You won't miss ballasted ignition on Cyprus, as it's primary function is to assist cold starting. The other thing it is supposed to do is extend points life, but that is not so much of a problem with moving heel points sets as you car should have.
I don't know how this tacho will affect electronic ignition systems. Someone else might though?
