Track Rod End Thread Size
Posted 09 March 2015 - 01:23 PM
any thoughts?
Posted 09 March 2015 - 01:29 PM
the bit with the taper seems to vary from manufacturer to manufacturer, if its original it could be 3/8 UNF IIRC. see if the thread looks the same as the wheel studs.
Posted 09 March 2015 - 01:42 PM
Posted 09 March 2015 - 01:50 PM
1/2 unf if you mean the locknut on the rod rather than the taper pin.
or not....
count & measure the threaded part to work out the pitch.
Posted 09 March 2015 - 01:54 PM
Posted 09 March 2015 - 03:20 PM
Should be 3/8 unf just checked
Edited by jaydee, 09 March 2015 - 03:25 PM.
Posted 09 March 2015 - 07:24 PM
Just tried a wheel nut and wont go on. Measuring on a venier calipers the thread is spot on 10mm and over 3/8. They are the compertition ones so not sure if that's makes a difference.
Hmm, yeah, it should be M10 x 1.25. There's something not right (bur?) if you can't get a nut on. Got another metric nut you could try?
The stock ones were 3/8" UNF, but the Comp ones are Metric.
Posted 09 March 2015 - 08:39 PM
Posted 10 March 2015 - 01:39 PM
Posted 10 March 2015 - 05:11 PM
Posted 13 March 2015 - 09:44 PM
Posted 14 March 2015 - 08:22 PM
Ok, finally got the m10 x 1.00 nuts through and bingo they fitted. So one for future reference
Hey mate, I hold you responsible here
I happened by chance to have a look at what I had in the draw yesterday, all the last one I bought were as you found - 10 x 1.00 mm, yet in the bottom of the draw, and I think they are a different manufacturer, they were 10 x 1.25 mm
Edited by Moke Spider, 15 March 2015 - 08:57 AM.
Posted 15 March 2015 - 07:48 AM
