1275 / 1275 Mg
10 replies to this topic
#1 Shawbags
Shawbags
  • 159 posts
Posted 06 March 2015 - 10:14 PM
Hi all , just wondered if the 1275 MG Midget engine block was exactly the same as a 1275 mini block , do you just replace sump with gearbox and clutch and drive gearing to suit, Shawbags.
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 07 March 2015 - 10:23 AM
No its not ... the rear bearing cap is different from what I know. You need to get a Mini block ..
Have you bought the Midget engine? May know someone that would buy it from you.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 March 2015 - 10:31 AM
Can be modified to fit, but no not exactly the same...
Plus if you're using an engine which had a side mounted gearbox originally you will need to change the crank too... eg Maestro, Montego, Ital, Marina, midget etc etc
#4 Shawbags
Shawbags
  • 159 posts
Posted 07 March 2015 - 06:38 PM
I thought it would not be simple , i only asked for future reference cheers both .
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 March 2015 - 06:42 PM
Best thing about Midget engines is the rods, will have 4 x AEG625 rods in there
#6 Shawbags
Shawbags
  • 159 posts
Posted 07 March 2015 - 07:08 PM
You would have to explain that one to me lol .
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 07 March 2015 - 07:18 PM
Midget engines are harder to get than Mini ones ... They made Minis for longer and replaced the Midget with the Triumph 1500 unit ... Sad, sad day.
#8 Shawbags
Shawbags
  • 159 posts
Posted 07 March 2015 - 09:20 PM
998 engines are pretty easy to get but 1275's are very hard to find .
#9 bikenutmart
bikenutmart
  • 579 posts
Posted 07 March 2015 - 09:28 PM
850s are becoming hard to find!! Mart.
#10 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 09 March 2015 - 12:37 PM
I think what Guess-Works is referring to it the Midget rods (AEG-625) are one of the best without going to forged, etc. See Vizard's book page 377.
#11 Shawbags
Shawbags
  • 159 posts
Posted 09 March 2015 - 04:59 PM
yes i've had a look cheers.
