Keeping Another Mini Out Of The Scrappy
#541
Posted 28 December 2016 - 09:07 AM
#542
Posted 28 December 2016 - 10:14 PM
You'll soon have it rolling mate. Only just a little bit jealous
Still a lot of work to do, plus looking at moving out this coming year so might get to a point and really slow down again
#543
Posted 28 December 2016 - 11:30 PM
Might catch you up after all then
#544
Posted 29 December 2016 - 06:02 PM
Subframe started like this on both turrets.
Then ended up like this
After getting both to the same state along with the back part of the frame I decided to pull the welder out and go around some of the seams and add so more welds.
I now just have the front parts on top to clean up and seam weld around the engine mounts.
It looks worse than it is because it was in the garage when I was doing all the grinding it has lots of metal dust sat on top of it.
If I manage to actually get up early tomorrow before work I will add some strengthening to the towers and add some triangle plates to the tie bar ears along with tying the floor mounting points into the frame. bought enough stone chip and black paint, to paint it once it's all done. Also thinking of opening up the drive shaft holes to allow the pot joints through.
All for now
#545
Posted 29 December 2016 - 08:18 PM
When I cleaned up my rear Subby the main problem I had was preventing it flash rusting before I painted it
Nice welding, what's the Wolf Compressor like, I heard some good things about them. I am rebuilding my shed and refitting my garage this year and need a more compact but more powerful compressor capable of running tools.
#546
Posted 29 December 2016 - 09:13 PM
My welding is actually good now days haha. The subframe is currently in the house 😏 So should be ok for now. Going to clean any off anyway and then quick coat of kurust before painting.
The small wolf compressor is good, I painted the car with it but now I have a 3hp 50L one and it's much better lol. Small one is good for little tools but struggles with cutting tools and you have to wait for pressure to build a lot
#547
Posted 29 December 2016 - 10:18 PM
Never really got on with Kurust and also tried Electrolytic and Citrix Acid Rust Removal during my resto but the best stuff I have found by far is Bilt Hamber Deox Gel.
http://www.bilthamber.com/deox-gel
Absolutely brilliant stuff!!
#548
Posted 29 December 2016 - 10:29 PM
I literally will go all out with different wire wheels and then with filament wheels until you cannot see the rust. Will then put a tiny bit on and that's it not failed me yet lol. I did that with my driving light surrounds on my 205 last year and no rust has come back through. I did look at using other stuff just never bought any cause I'm lazy haha
#549
Posted 31 December 2016 - 07:57 PM
#550
Posted 08 February 2017 - 10:03 AM
All for now
#551
Posted 08 February 2017 - 11:35 AM
#552
Posted 08 February 2017 - 01:10 PM
before you spend ages on subframes, I have been quoted £80 to blast and powder coat including zinc rich primer for both front and rear frames, but looking good
#553
Posted 08 February 2017 - 08:50 PM
I need to find some where to get that done will be quicker and easier
#554
Posted 08 February 2017 - 09:22 PM
I'll ask my nephew, he knows someone who does powder coating. May be worth getting mine done as well
#555
Posted 13 February 2017 - 07:10 PM
That seems very cheap for both?
