Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#451 James_eaton_thewholething
  • 1,063 posts
Posted 16 July 2016 - 07:37 PM
Still carrying on with the body work to get the car ready for primer.
0E00389B-2F93-48F6-80F0-350E795AD0EE_zps
Biggest part of body filler nearly finished.
In between body filler drying I've been working on my inlet manifold to remove casting marks and remove the locating ring ridge.
D44753E7-1EE2-4963-BCF2-13E76B60989D_zps
This is how both sides started. There was some bad casting lumps that needed to be removed.
FA7B0351-FEFD-4D29-B298-26C4A52EA696_zps
The locating ring lip was obstruting at the top and also a flat edge.
A5CD7D82-C220-4FF9-B08D-A8E8DD327279_zps
C9906EFE-90F2-44AC-A8BD-7BD4C644CCA2_zps
This is one side part way through.
92E345A4-F4D0-4941-9089-F856EE74DE45_zps
DB9E73A9-4639-49D4-93E8-51EE4AF2DD50_zps
3C1E175B-50D2-400C-B5A3-934DDB68A06E_zps
This is it finished. Left a slight rough finish to help with fuel atomisation. It was good practise for when I start on the head to match the ports
Aiming for primer on passenger side middle of the week
All for now
#452 James_eaton_thewholething
  • 1,063 posts
Posted 26 July 2016 - 02:06 PM
So still progressing even though it's stupidly slow.
9EB0CEAA-A578-4C39-8900-A0F2AC3D1234_zps
6D1A7EDD-03CC-44C9-A0A0-826AACEFB3CD_zps
Back end body filler finished
22295481-CD4F-4BB5-9DE1-D4A4DD94D7AF_zps
E5B0F2D7-13D9-4F3A-9C70-C1265D682EC3_zps
Also re primed the waist rail and B post ready to just quick rub down and throw some colour out of a can on them. Just need to try my best not to scratch them when putting the car back in. Got a few bits to finish on the passenger side then get the primer on. It's taking so much time up but at least it will be right
All for now
#453 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 26 July 2016 - 02:15 PM
Getting there matey :-)
#454 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 28 July 2016 - 05:37 AM
All this takes time but is all worth it in the end dude when the get that nice smooth finish at the end.
#455 James_eaton_thewholething
  • 1,063 posts
Posted 28 July 2016 - 04:18 PM
I know, just taking its time but it's definitely better than the last time I did the things. Aiming to finish rubbing down over the weekend then hopefully primer Monday all being good
#456 Daz1968
Daz1968
  • 2,058 posts
Posted 28 July 2016 - 07:25 PM
Trouble is with bodywork until the top coat is on it's difficult to see anything for all your efforts it's very time consuming and you end up with most the filler on the floor, you are getting there though now
#457 James_eaton_thewholething
  • 1,063 posts
Posted 29 July 2016 - 11:37 PM
Got a delivery today.
386AAC9F-B032-46BA-BE66-FF948C5E67D6_zps
As my original arches were thin and not shaped very well I decided to buy some new ones from the arc angels. While I was at it thought I should buy bumpers too. The bumpers come with mounting brackets but won't be used so they need to be cut off.
DBEB57B6-8404-46CA-9CAE-6E879A9AACD3_zps
03DBF489-EE99-422D-BDD7-C61FB96F3239_zps
Got the arches fitted up. Now as I hadn't used these first the holes are a bit out. Got that sorted though but in the mean time because these are a lot thicker and less flexible the passenger rear cracked a little. Fixed the issue by drilling new holes in the rear valance. The old ones will be plugged up with blanking plugs as cannot be bothered to weld them up. Plus would give me access to be able to spray waxoyl in the enclosed valance sections.
43802EF9-B794-436E-9C35-BCA421165E89_zps
Cut the crack out so will just put a bit of fibreglass filler then skim of dolphin glaze.
5CDD0D30-92DE-494B-9DC6-BA3073FC4B45_zps
Test fitted the rear bumper. Needs to be trimmed a little but cannot wait to make brackets and fit them for final.
D86D36FE-EEE9-48DD-98A7-1BBB38E9FF48_zps
Then finished the day with a small steak
And super noodles .
Will finish fitting the drivers front arch in the morning and then carry on with the body filler
All for now
#458 James_eaton_thewholething
  • 1,063 posts
Posted 03 August 2016 - 08:38 PM
Update time also it's important up date time.
So all the body filler is finished and then this happened
12F4CC72-D656-49BD-94F9-3534B8F772BC_zps
AEE24928-69FC-4C24-9CFE-10807232DB89_zps
So after that happened on one day then on another day other things happened and the other thing was this.
B6376485-3194-4F09-A832-90E80F1E4EEB_zps
D051F04F-78EE-4175-8F5F-63CD991DF2F6_zps
I literally ran out of time to get the last coat on. So this has 5 coats on and everything else has 6 on so will add one more hopefully tomorrow.
F566D774-B1E1-443D-A78F-89D33E70649B_zps
CA3AD5A7-EA4F-4C66-B11E-D35CE89FB0B7_zps
Always worried about getting these bits smooth but now with primer on I'm happy. Along with this I tried something else out.
Now this really shouldn't work at all as its been sitting outside in the rain, snow, heat, dog probably pee'd on it a lot over the past year and a bit. So I was very surprised it started up and the motor bearing don't grind or anything. Only left it out side as I wasn't going to use it at all and decide I might as well as it will be cheaper to replace the matrix and clean up and re paint the case than buy a small heater and make up mounting points. Plus it's only going to but used as a heater and not to demist the windscreen as using a heated one.
Going to finish the last coat and then get started on rubbing down and hopefully move onto colour Sunday/Monday feel excited again now
All for now
Edited by James_eaton_thewholething, 03 August 2016 - 10:25 PM.
#459 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 03 August 2016 - 09:22 PM
Nice one, gonna look great!
Can you bring Yoda round to piss on my engine? You never know his magic pee might get it going
#460 James_eaton_thewholething
  • 1,063 posts
Posted 03 August 2016 - 10:27 PM
yeah mate anything else you want his force pee on ?
#461 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 03 August 2016 - 10:35 PM
If his force is strong he can pee over the whole car!
#462 James_eaton_thewholething
  • 1,063 posts
Posted 03 August 2016 - 10:44 PM
Unfortunately he is a lightning Jedi Pokemon and can only sort out electrical parts and some engine bits haha
#463 GT Jimmy
GT Jimmy
  • 1,676 posts
Posted 03 August 2016 - 10:47 PM
Never mind, worth a try
#464 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 August 2016 - 10:55 AM
6 coats  :ohno:
#465 James_eaton_thewholething
  • 1,063 posts
Posted 06 August 2016 - 12:12 PM
6 coats  :ohno:
Haha yeah only because by the time I had done the drivers side that's what it was at lol. Plus wanted that extra safety net for rubbing down. I'm currently rubbing down and it's been good for the fact that I haven't gone through yet. Doors, bonnet and boot lid will get sensible amounts. How many layers of colour is the norm ?
