Keeping Another Mini Out Of The Scrappy
572 replies to this topic
#391 GT Jimmy
GT Jimmy
  • 1,634 posts
  • Local Club: S.U.N.M.C
Posted 28 April 2016 - 08:52 PM
Good luck with the paint mate. gonna look good
#392 James_eaton_thewholething
  • 1,063 posts
Posted 29 April 2016 - 10:11 AM
Will look good if I ever get chance to throw paint on it lol
#393 GT Jimmy
GT Jimmy
  • 1,634 posts
Posted 29 April 2016 - 07:21 PM
Ha Ha then you get me and r kid turning up getting in the way
#394 James_eaton_thewholething
  • 1,063 posts
Posted 05 May 2016 - 03:52 PM
Bit of an update. She'll isn't in colour yet but is partly in primer.
The whole shell was put in zinc primer first
40A2502C-2329-4B51-B6CE-52CEE2CCDDD7_zps
2D6B341B-9D94-4456-8B20-EF2CCB96709D_zps
Also put bits of stone chip on high traffic areas. Really wish I hadn't now as you will see why.
So after leaving the stone chip and zinc primers to dry over night I decided to get on with the high build primer. This lead me to a lot of stress.
97AA2753-868B-4500-B361-48F11127A95B_zps
So yes I got some splitting going on. The worst places were on the outer sills, bottom of the front panel and rear valance. These were areas that got painted a very long time ago but hadn't seemed to have dried out properly. I had no clue why and what was really weird is panel wipe made the stone chip go soft and sticky. Obviously the reason why the paint split.
After trying to sand it down till the paint was hard and panel wipe wouldn't soften it I tried again and it still split. So decided to strip all the stone chip off the affected areas and start with bare metal and try again. In doing so this happened
BAF2ED97-068C-4DFF-8193-3EFB25F75331_zps
Let's say polyabrasive disc on a grinder + shorts = 6 stitches.
After I have now finally removed all traces of stonechip, which came off easily with thinners ( kinda wish I had tried that first ) the car was then primed on the areas that were stripped back and it hasn't split. After work tonight I will rub down the little bits of runs and feather in the paint edges ready to put another 4 coats of primer the whole car tomorrow.
C2D0B8ED-F10E-4880-9758-F1223B7046F8_zps
Also got my brake bias gauges waited ages for it to be in stock. Can finish the dash off fully now
All for now
#395 mina08
mina08
  • 255 posts
Posted 05 May 2016 - 04:25 PM
whoops :) looking forward to seeing the final colour :)
#396 Daz1968
Daz1968
  • 2,058 posts
Posted 05 May 2016 - 05:35 PM
Grinders can be dangerous and when they bite it hurts, could of been worse I bought some fire retardant trousers and always where them when in the garage as in the past when using cutting discs have had my normal trousers set on fire. Hopefully you will be back to normal soon. Looking forward to updates
#397 James_eaton_thewholething
  • 1,063 posts
Posted 05 May 2016 - 05:44 PM
I have welding jump suits that I usually wear just. It was warm and I was already stressed so was in a rush. Was totally my fault. It being in colour will be a massive step. Will mean I can start with all the little bits and pieces then
#398 GT Jimmy
GT Jimmy
  • 1,634 posts
Posted 05 May 2016 - 05:47 PM
Oh dear oh dear! That's gotta hurt. The health and safety police will be round later
#399 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 05 May 2016 - 05:57 PM
Hi mate been following this, great work so far leg looks like it hurt.
Anyway please don't take this the wrong way but I'm sure it's the zinc primer causing you reactions is it weld thru primer if so this really don't stick well to bare metal as I found out and ended up buying some quality etch primer.
I usually etch prime then high build prime.
#400 James_eaton_thewholething
  • 1,063 posts
Posted 05 May 2016 - 06:44 PM
Thank you for following. Leg wasn't to bad
I won't take anything the wrong way when it's helpful. The zinc has been ok actually. The roof was coated in it before the high build and didn't get issues. Some of the areas I used zinc on didn't wipe away with the thinners and had to really sand it off. Stuff like on the door steps, outer sills, front panel and rear valance only had the stone chip on and they were the worst of the reactions. Zinc primer on the rest of the car was also fine with the high build over the top. The roof was literally bare metal then keyed up with like a medium sanding sponge then zinc primed, high build and colour that was painted about a month ago now with no issues. With the stone chip it was like all the solvent hadnt evaporated properly. It only seemed to be those areas as well I painted the inside of the engine bay and boot over the top of stonechip fine so not sure why lol
#401 James_eaton_thewholething
  • 1,063 posts
Posted 05 May 2016 - 06:46 PM
Well I was wearing a face shield at the time so that has to count for something. I have a picture of the cut but wasn't sure if I should post it up or not lol
#402 GT Jimmy
GT Jimmy
  • 1,634 posts
Posted 05 May 2016 - 06:56 PM
Did you cry ha ha
#403 James_eaton_thewholething
  • 1,063 posts
Posted 05 May 2016 - 07:03 PM
Did you cry ha ha
Nope. Did it about 5:50pm and didn't go in the house to clean it up till about 6:15pm had to finish clearing the panel off
#404 GT Jimmy
GT Jimmy
  • 1,634 posts
Posted 05 May 2016 - 07:14 PM
Did you cry ha ha
Well aard
#405 James_eaton_thewholething
  • 1,063 posts
Posted 06 May 2016 - 12:39 PM
So still having issues with primer in places so as I've had enough of it and don't like some of the body filler in some places. The shell will be back to bare metal and start from scratch. Would rather do that and be happy in the end than keep trying to sort different bits at a time
    Bing (2), Google (1)
